Lockwrong not right
Mountain Hole, Idaho
Question about the funtion/misfunction on a lockright.
Maybe 100 miles on a rear lockright sometimes when I turn corners the lockright enganes harshly. Most of the time it happens when I start out turning into a lane, then BAM., sometimes it happens just once, or sometimes it is multiple times until I straighten out. Form my limited experience with lockrights, normal enggement around corner should be a racheting sound, not a harsh BAM! What is the cause and remedy for this. Thrust washer clearance?
Driving style.
Try coasting through the corners or keep the throttle steady for the duration of the turn. Constatn changes in input torque (repeatedly accelerating & compression braking - even small amounts) will cause it to lock & unlock instead of ratcheting predictably.
If you do it consciously for a couple days, it'll become second nature and you won't even think about it.
mel lowe said:
You do have the same size tires on the back don't you?
And make sure that one tire does not have too low of air pressure.
Checking the thrust washers requires what, 30 minutes and a little gear lube? Do it....
"generally", a loud/abrupt locker bang when under load will indicate too much gap where the pins/springs are. I've had it front and rear on mine, replaced the side thrust washers, and it vanished.
washers are $20 a pair (or so) from CDan, get the thickest (.170 IIRC) and toss those in there.
ya say ya just installed it 100 miles ago? what were the clearances? (ya DID measure, right? lol)
I must clarify, I installed this about a year ago, during a complete teardown and build up of my cruiser. Only has a 100 miles on it since it just starting rolling under its own power. If memory serve correctly there was nothing in the directions about measuring the clearance. That is more than likely the problem.
As for those that say its normal, never seen one engage this harshly. It will actually move the rear of the vehicle sideways. THe ones I have seen installed correctly would ratchet going around turns, not throw you sideways when it engaged.
ranger said:
As for those that say its normal, never seen one engage this harshly. It will actually move the rear of the vehicle sideways. The ones I have seen installed correctly would ratchet going around turns, not throw you sideways when it engaged.
It all depends on your driving style.
It still sounds like normal operation if you are driving around corners just like you were with an open differential. They will only ratchet smoothly if you decelerate all the way through the turn (or accelerate ththe entire turn). If you accelerate out of the turn, it will switch driving sides and do exactly what you describe. All auto lockers hate going from accelerate to decelerate (and visa versa) in turns, so you have to change your driving style.
Read the above slowly and remember it every time you goose it around the corner.I 2nd the driving style. My last cruiser had them for 10 years and right from the git-go did it,every now and again it would SLAM,truck would shift a little
until i learned the rears,because the will not adapt to you......good luck and mellow the corner.
