JT outfitter front disk swap75 was still drum and used the coarse six spline. Later disc brakes used the fine spline spline. Really depends on if the front axle is going to stay original drum brakes or converted to disc brakes. Disc brakes really need to be sure what parts were used to be 100% sure.
Most likely coarse spline. It's probably best to remove the existing lock out or drive flange and see what you have.JT outfitter front disk swap
