Locking hub dilemma.
stuart island BC canada and Costa Rica
My HDJ-80 is a 5 sp. manual with Aisin locking hubs. I had the front jacked up today to replace my shocks and thought I would try the hubs out. Pass. side works good (when locked, the drive shaft turns with the wheel.) But the drivers side doesn't. Free or locked position makes no difference.
I did the hub rebuild last month and everything seemed fine in there. Any body have a clue as to what to try. I have watched the utube vids on the hubs but no hints there
Thanks.
Could the splines on the hub gear or the outer shaft (CV joint) be stripped?
The splines are fine and in the am I will check the indexing
thanks
Sound like your springs are not rotating down the hub fuse to engaged, i believe aisin have a spring holder that is indexed into the slots of the fuse and this may be spinning along the spring instead of locking down or the spring is spinning in the holder...the spring goes into a little nook that locks it down. sounds like your spring keeper is bent wrong somewhere
I watched the vid on how to rebuild them and will check springs in the AM.
Took the hub apart this morn. As you can see in the picture, there is only about 1/8" of splines after te snap ring. That's not going to work. Is there different Birfs for full and part time diffs? Because this is Costa Rica, the Mechs here are not the sharpest tacks on the board.
There are two different lengths of Birfield CV joints for the 80 series, one is ~8mm shorter than the other. AFAIK the longer birfield however will not fit inside the AISIN hub for part time models unless a second lock ring groove is cut 8mm further up the stub shaft of the birfield. Here's a link to a discussion and photos:
Longs with Aisin hubs install
Thank you all for your help and suggestions. I watched the "How to" vids again, and found that mine was put together wrong and so would not slide all the way in. Typical of the shoddy workmanship here. I reassembled it correctly and now have engagement.
Thanks.
That's correct Kernal, Someone had installed the spring keeper wrong so that the locking mechanism would not slide in.
Ive had several hubs over my career have had similar but different spring problems...even the slightest wrong bend along the springs path and the way it pulls and lowers the fuse, the way the spring loops and locks into the keeper is also a recurring issue, the way the keeper tabs are bent, it all has to work together to get it right.
