Locking doors automatically
Maine
So, I've noticed a new issue / feature with my door locks. When I start the LC, all of the doors lock, but, when I turn off the LC, it only unlocks the drivers door. When I set the alarm, it locks all 4, when I disarm the alarm, it only unlocks the drivers door. Am I going crazy, or how is it supposed to work?
Sounds right, but don't have any of those features on my 80. My 4r if you press the fob twice to unlock will unlock everything. But the 4r does not have auto lock at start or 5mph or whatever.
Might be the alarm is mis-wired.
The "unlock" wire from the alarm is normally tied into the PS door's key cylinder switch. (I believe)
Edit: The alarm is usually tapped into the connector that goes from the DS to the PS door.
The door lock control relay has a dedicated input for the DS (key switch) unlock. The DS key switch requires a double action to unlock all the doors. This may be the circuit the alarm is connected to.
I don't have an alarm, but that's how the doors lock/unlock on mine. Annoying as hell.
Do your doors lock when you start the car? That's an alarm function.
I don't have this issue on my poverty pack 92 but that is what my Camey Hybrid does.
I thought I had read somewhere on Mud where you could "program" the keyless entry.
Before I removed my alarm, all of the doors would unlock together.
I suppose. If I have an alarm I've never used it. Maybe I'll dig out that key fob thingie someday and check it out.
:meh:
That sounds about right. I believe my alarm acted that way before removed. Although I think mine locked when the truck started to move.
I don't have the rs3000, I get a different locking process every time I start her up. It's a gamble. I haven't gotten locked in yet.
So now that I've had a chance to really look into the door lock control circuit, I see that there is only one set of outputs from the control relay. All of the door lock actuators are connected to this one output. The driver's door lock is wired directly, all other doors are wired through a connector. Perhaps some alarm systems interrupt this connection going to the other 3 doors (and hatch). My system (the TVSS I think) wasn't wired this way.
