Locker options
Good to know. Thanks. Have you seen this option before in an LX or 80?
Which option? Front/rear lockers? I have them (original equipment) in my 96 LX, many people have them in both Toyota and Lexus trim.
CDL switch? I added it as well as doing the pin 7 mod, as probably hundreds of others have, who frequent this forum.
I recommend you read through some of the FAQs to get a better understanding of the 80 series.
IH8MUD 80 series FAQ
Slee's Newbie Guide
OK, so that CDL switch can be added to a vehicle with the factory lockers? And even if you don't have the front and rear lockers this will give you 4WD HI? Otherwise without that switch you are just running AWD (if you don't have front and rear lockers)...?
Nothing jumps out as a reason to run from it, though I would never even consider it. If low miles is very important to you, it might be what you are looking for. To me a 50k mi 80 and a 120k mi 80 are not much different, as they should last to 300k+ without much issue. You should be able to get a FZJ80 for half, or less, than that rigs asking price, with 120-150k miles on it. But only you know what low miles is worth to you.
From the pics it looks real clean. They have Bridgestone Dueller A/Ts on it - which is not, by far, a hardcore wheeling tire - that is a good sign for purchase. However you need to go there and view it in person - or have another knowledgeable member examine it for you if you are not in the Cincinnati area. This is a cool board, ask and I am sure someone will check it out for you if they are in the area.
it looks like that switch was put in place of the manual antenna up/down button...the seller sent me a picture of the button but the file is too big to upload. the button is above the climate control cluster...
I would certainly only offer much less than he is asking but OVERALL condition is fairly important to me as I try to keep my vehicles in good condition. I live in Columbus, OH so Cincy is only 1.5-2 hrs away.
the PO used the term "console" and I followed suit because I couldn't actually see where it was...I went round and round with him as well in a cloud of confusion...sorry.
Not really correct. A CDL switch can be added to any 80 series. All 80 series already have the CDL, some have a switch (91-92), some engage automatically when put in LO (93-97). When the CDL is locked you are operating in "traditional" 4wd (ie. same as a 1980s pickup truck) whether you are in HI or LO. The front/rear lockers are not related to the CDL, except that the CDL must be engaged for the computer to allow the front and rear to lock.
Please quote the post you are responding to or asking about, when you do a follow up post, so we can see what you are trying to find out.
am I not doing something right? a rig w/o the CDL switch won't run in "4WD HI", right...only "LO"?
Correct, w/out the switch it will be "AWD/Full-Time 4wd" HI.
but I thougt AWD and 4WD were different...AWD is power to 1 wheel, 4WD is power to 2...
AWD with center unlocked = all wheels driven unless any 1 tire looses traction
AWD with center locked = all wheels driven unless 2 (1 front and 1 rear) tires loose traction
All 80s have the center diff lock and will automatically engage when placed in Lo range.
1991 and 1992 80s have a switch that allows you to lock the center diff in Hi range.
MODS
93-97 can have a switch added to allow you to lock the center diff in high range.
all 80s can have the pin 7 mod done which removes the automatic function of locking the center diff in LO range and makes it selectable through the added switch previously mentioned.
MODS
WROD.
Can we move on now??
:D
