Locked NOt seized 2F
I had a similar issue with my 71. Frozen from sitting for over a decade Here is what I had to do to free it.
1- soak each cylinder for several days with your favorite penetration oil
2 - Yank head off and remove any visible bore rust with 1000 grit wet/dry cloth
3- Drop oil pan
4- disconnect all connecting rods/caps.(make sure to mark them for reinstallation in same cylinder and orientation
5- find which cylinders are frozen
6 - trim a 4x4 post to fit nicely in the bore to the piston
7- hit the frozen piston(s) free
8 - remove each piston and inspect piston and bore for issues
9- do a light cylinder hone
10- reassemble
All the above you can do with the engine in place.
I can't remember which pistons were frozen but I do remember I had to use a sledgehammer to free up one of them.
I would recommend replacing rings and all bottom bearings since you have it all apart.
Spot on kckfj4o! Thats welcome news as my facility is somewhat limited.
Thanks!!!
Currently, my spidey sense is leaning towards a spun bearing. Bottom up will be my direction. THANKS!
Probably not “spun”. But merely seized from lack of oil. A spun bearing would make a knocking noise, but it would still rotate unless a rod was sticking out of the block. Check the distributor to make sure it is seated all the way. Do the easy things first.
