- Joined
- Jul 6, 2013
- Threads
- 71
- Messages
- 1,702
- Thread starter
- #21
Ah, and what happens if I break that bolt for the lower shock mount in my driveway?
Step 4:
Now remove the bottom shock mount bolts.
Be extremely careful with this bolt. If it does not come out easily, re-apply penetrating fluid or heat the mount with a gas torch. This bolt breaks very easily and is most often rusted. If this bolt breaks, you are in for a long day of drilling and tapping. Resist the temptation to turn up the air impact. This might just snap it off. Most often it is best to use a long extension pipe on a breaker bar and put gentle pressure on the bolt until it loosens up.
ahh.. I broke that one once.. cut it off, welded a bolt in it's place used the head against the axle and the threaded part to secure the nut on the other side. Or in some shock kits there are "Pins" that fit well.. can weld one of those on there.. Not a big deal.. Or weld a nut to the part that's left and let the heat from the welder break the threads loose.
lots of PB, then I typically heat up any bolt that will not come out with moderate pressure. Heat it up with torch, the spray PB blaster to cool it down and it sucks in the pb. Then heat it up again and use my light dewalt impactdriver (not impact wrench) to zip them out.
If bolts start going out easy, then get harder, this typically means that there is rust or corrosion on the bolt past the nut. Just run them in and out several times to get them out. Kind of like using a tap.
Goto harbor freight get pn 66686 and use that to pop stabilizer off. Use the one that looks like this. In this manner. The one I have is from otcspx. Imagine the tangs grabbing the od of the hole the stabilizer is inside
Sent from my SAMSUNG-SGH-I537 using IH8MUD
Im not sure the monkeys at a place like that are mechanics. U have a jigsaw? A hand drill and a bench vice?
