Also, here is a thread with a few pictures of the first V8 Prado in BC Canada: https://forum.ih8mud.com/threads/uzj78-1uzfe-into-lj78-north-america.856990/
Hey Fraughton, Great to see someone else in the same boat! Very cool that you are going 5spd with your swap. I assume your truck was already 5spd? You might encounter a few less issues not having to sort out the Autobox.
Interesting to hear that you had to install a body lift, I didn't run into that issue. I ended up sliding my UZ forward 3/4-1" to gain some firewall clearance and the factory headers seem to fit with no issue.
Do you have a suspension lift in your truck? A 3" Lift will help a lot with your pan clearance. Even with that though you will have to install taller bump stops or clearance the pan a little.
How are you making out with wiring? That is where I have run into a bit of a roadblock. (Just lack of experience) I have now (just the other night) Opted to pull the entire harness off the engine (Trying not to break as many connectors as possible) So I can delete as much as possible in the efforts to make routing the harness into the truck. I have a USD 1uz so the harness comes out on the prado drivers side. I am going to attempt to mount the ecu under the dash but being that is is quite a large ecu I might have to run it into the glove box.
In your post you mentioned that you were going to order engine mounts? Where did you find these? I ended up modding the stock prado mount to attached to the UZ. Its ugly but it works, and they are hidden well by the headers so nobody can judge haha.
Let me know if you need any help. I have done a truck load of research and have tons of different wiring diagrams for the ecu plugs and junction (body) plugs. My swap is going extremely slow as I have been in the same boat (moving around) and my 2 year old takes up alot of my time. But I try and get out there for a few hours every week. I am lacking in the updates and I really should get on it as I have got a bit done since my last update on my thread.
There's also this Engine Mounting Bracket Lexus V8 | Lexus V8 Products & Services | Akasia, Pretoria | JM Lexus V8 Engine Conversions | Akasia, Pretoria that I've found for engine mounts, but I'll likely go with the former.
A while back I found a company in NZ that advertises on facebook and has done many 1UZ into LJ78 swaps. They had lots of pictures of a swap they had done. I saved all the pictures to my computer in case I ever did the swap myself. I figured I may as well upload all these pictures for you guys to look at too. Might give you some ideas and answer some questions.
Here is the album; there are about a 100 photos there:
1UZ LJ78 Pictures
Has anyone tried throwing an LS1 or other small block American V8 into a 78 yet? Seems like an obvious choice in North America. I would think the sheer number and variety of upgrades available for that motor would make it a popular swap. What obstacles am I not taking into account?
Ask Tor if the Cummings 2.8 in his rig would work in the lj78! I want to know.
I need details!
