Little Things
Tucson, Arizona
I received and installed my replacement hood and rear window struts. Simple but no less satisfying to have a hood and rear hatch that opens and stays open.
I'm trying to find an alternative antenna to the telescoping OEM one. Previous owner replaced it no less than 5 times according to all the maintenance records and of course, it broke again on him the day I bought it. Any suggestions?
Also looking to source the HVAC buttons on my 2000 dash. The fan off button, the fan speed button and the rear defrost could all stand to be replaced. Anyone have and leads on either the buttons or the whole HVAC insert?
I also got the CV axle and the rear OME shocks for next week brake and suspension work. Baby steps.
is the telescoping shaft breaking on the antennae?
something is wrong, the stock antennae assembly will last a long time without issue
I guess it's technically not broken but it appears to be crimped and won't retract entirely. I think the PO would argue with you about the long lasting OEM antenna. I don't know the PO personally, but If I replace this one, it will be the 6th on this vehicle.
The guy I bought my 2000 from said the antenna didn’t work and was stuck down. He had a few records of having it fixed. I thought I got it figured out the day I bought it, then driving down the road I turned the radio on and the antenna went up and kept going up until it pulled completely out and was resting on the passenger window. I’m still debating trying a new OEM or going with a fixed aftermarket antenna. Good luck with yours.
My working power antenna is one of the weird things I love about my LX470. Buy the replacement mast, remove the motor to ensure no broken pieces are stuck inside, throw some grease in it and enjoy it.
You can get a flex generic antenna or the manual extend one on the Tundras, there's threads on both of those. For the HVAC controls, you could look for someone parting out their rig here or see if it's available new, get the parts number on one of the good diagram sites like Partsouq, then buy from the SE dealers during a sale.
Thanks. The part numbers(55902A or 55905G) for the HVAC buttons in PartSouq are not available there. I checked Bell Lexus and can’t find it there either. I’ll keep digging.
Maybe I’ll drop the $82 with Bell Lexus for the antenna and just see if maybe I’m able to take better care of it than the PO.
Swapped my telescoping antenna for this fixed stubby unit: https://www.amazon.com/dp/B07BB4KT2P?tag=ihco-20
No idea on differences in reception as I don't listen to the radio, but I did confirm functionality after installing.
Yeah, I’m torn on replacing the OEM retractable antenna or getting a fixie. I’d like to pull the old radio and replace with a CarPlay friendly head unit but that’s down the road.
