Lighting or Electrical Guru's advice needed!
Bend
Need some quick advice.
I'm wiring up a rear heater fan switch to switch between fog & driving lights that will be mounted on my ARB.
I have the switch wiring figured out from reading posts here, but am having trouble identifying a good wire to tap into the parking lights.
I don't want to tap into the parking light wires near the battery (DS on my 97) because I've already modded the turn signals & front corner light to alternate when blinking. (the mod mentioned here on Mud & Daniel Stern Lighting website). I think there is a wire I could use that won't cause my fogs & driving lights to blink also. Just not sure which one to use.
Just basically need a good source of "Key On" power that is not tied directly to the low or high beam circutes as I want the flexibility to run the lights only with the parking lights on.
So, I've done a bunch of research here on Mud and everyone seems to like tapping into the parking light to power the switch is the best move. And yes, I'm running a separate wiring plan with relays, etc. for the new lighting.
Is there a parking light wire accesible in the cab to the left of the steering wheel or in the lower left kick panel?
I've done 7 Pin and added a navigation head unit to my rig so I'm not afraid of digging through various connectors to get the wire I want.
Any help would be appreciated as I'm trying get the lights installed before a road trip leaving on Thursday. Sure would be nice to have the driving lamps for dark back roads where I'm traveling with the family.....
Thanks!
- Dave
