Lift advice
I've been thinking more about my preference of Slee over FOR and want to be fair here.
I naturally avoid the type of ride quality that the FOR setup provides and while thinking about it this morning I think it's only fair to explain why.
When I was younger I had a predisposition for car sickness or motion sickness. I almost always had to ride in the front seat to avoid it. But a friend of the family had a Caddy that I had an occasion to ride in. This is back in the early 70s and they were a floating barge of a vehicle and regardless of where I sat even the front seat I could count on blowing chucks with in a mile or two.
Now I road in that truck for an entire afternoon without incident but it's just part of my makeup not to like it.
First off... :lol:
secondly this is how my J spring/bilstein rode in the back...the bilsteins really soaked up the harshness better than OME, but they also allowed more bounce after initial bump.
Now I'm really wanting to ride in a FOR equipped vehicle to compare.
Thanks again for all the feedback and real life advice it has been a big help:clap:
After much debate and lots of different opinions I ended up calling
a few vendors about my options,I decided to go with the J's&L's up front and the heavies/N74 for the rear.
From what everyone is saying I believe this is the best combo for me at this time. I believe this will give me what Im looking for... NO Stink Butt. I more than likely will eventually upgrade to Slee 4" but at this time I just dont think I am heavy enough for such a stiff spring.
I did end up ordering from TRDPARTS4U best price around on a OME lift that I could find... $599 delivered
I am going to get my caster measurements before and after to see what kind of change I get out of this setup... I will follow up in a few weeks with more info on the install and amount of lift I actually get with this combo on a lightly armoured truck.
Thanks again Jason:cheers:
I have been extremely happy with my setup. The CC bushings didn't even get me close with my J's up front (I have a thread with detailed numbers). I ended up with stock bushings and Landtank's plates which put me perfectly in spec. I lucked out and do not have any driveshaft vibrations (still can't figure that one out). I could not see running 35's on my setup since I can get my rear tires to tuck all the way in and touch and wouldn't want to limit the travel I have since it articulates really well. Also I run chains a lot in the winter snow that would definitely cause some rubbing. I had to get rid of the J's in the rear because of the stinkbug and now it sits pretty level even when loaded up. It handles great on the highway and I don't notice any body roll. Speed bumps are soaked up real well without any bounce in the back. I think it's the ideal setup for 33's.
TOY350- do you have any pics? Preferably some side shots on level ground? Thanks much, Dan.
Wow, just looked through my pics and I don't. I will try to take a couple tomorrow and post them up for you. Got plenty of shots of it in the snow though :)
Post up a few pics if you want, I dont mind I actually would like to see how it looks:)
Here are some that give you absolutely no idea of the lift from front to back but do let you know that snow is fun :) I will take some shots tomorrow on level ground so can see how it sits.
I never understand these threads. Where did
I also want as much lift as possible without having to do a driveshaft or other additional items from the get go...
go out the window with the choice you made? Right of the bat, you need to address the front driveshaft to swaybar contact in the front as well as the length of the brake lines. Either new brake lines or drop the mounts.
arent we are still allowed to change our minds, especially when we ask for OPINIONS to influence our decisions :D
I am not saying that people can change their minds, I am just amazed that people change their requirements and then start compromising on what they buy. I am not pushing our suspension, I just don't see how going that route is not going to open a can of worms. Maybe I am not totally objective on this, but believe me the number of calls we get from people that have issues with their trucks due to suspensions are staggering. Mostly due to not doing it right, or not listening to advise, either obtained personally or on forums.
Now i barely had the slightest grrrr's but only when letting off during acceleration and slight wandering on the hwy.
Our experience with this is that a slight GRR only gets worse and slight wandering is what gets you in trouble when you make emergency maneuvers. Disregarding these two issues is not something we recommend.
Good advice :)
I think J's at right at the point of possible issues with vibrations/caster problems.
I have a vibration free straight driving truck...and I have Caster plates, DC shafts, upper rear. I'm setup to go up to 4" if I want, but currently at J/heavy.
Not saying it's the only way, but it works nicely.
Why not? That is what this :bang: is for :D
I'd push the Slee 4" kit for the average user as it solves for everything out of the box. You can back down from that in certain areas or make modifications, but at the end of the day that setup represents a real sweet spot in the range of lift vs. tire size and corrects for all of the possible additional considerations. To be very clear, Slee's 4" kit is the only truly complete suspension for 35" tires on the market.
F.O.R. is very close, but you can make arguments about caster correction and adjustable panhards that draw distinction between the two, and their price points, independent of loaded vs. unloaded spring heights that represent differing design/usage premises.
That's interesting. My childhood in the car (a 1970's Ford station wagon and other vomit mobiles) was pure hell. I still get sick even as the driver in a low slung and softly sprung car on a winding road. This is a major reason I love the high seating position and truck feel of a solid axle 4x4 with big tires.
I've never had an issue as a driver or passenger with my 80, but I can absolutely buy in that some people have a preference for a stiffer suspension. I am one of those to a fairly extreme degree.
All things to consider as you make a decision on buying a suspension.
Extended brake lines at full flex was the only other change I had to make with my J's... No driveline issues or vibes. As for the sway bars, they ended up in the garbage.
