Lift advice
Palm Bay, FL
Alright let the flogging begin:doh: I have been searching for a year and still cant make up my mind as usual:confused:
I am ready to purchase a lift for my truck but cant decide which springs would be best...
I am currently stock except 295 tires and sleesteps.
I am in the process of planning/building bumpers so keep that in mind. I also plan on a 9500 or 12000# winch, 35" tires and eventually a drawer setup.
I prefer a level stance and not a stinkbug.. I also want as much lift as possible without having to do a driveshaft or other additional items from the get go...
Does anyone think I would have a problem with just doin J's & L's?
I know I have alot to learn so please shcool me. It seems like too many choices:bang:
Thanks in advance for the info and advice:)
Just from hindsight and experience go Slee 4" or you'll find yourself going what if????????
This is were I ended up but not where I would start. I'd put on the Js and all the other associated pieces that would make a light truck drive properly. Then once I added all the other weight I'd swap in Slee's springs and be done.
A stock truck on Js and a loaded truck on Slee's 4" springs are almost identical in height. This way your not sprung so stiff when light that the ride suffers and you basically work out the geometry once.
The other possibility would be going with FOR for springs as they seem to handle the transition from light to heavy weighted better.
At this height and tire size you are really raising the CG and the best defense for roll overs is a properly set up suspension. But all this cost money and since it's not outwardly obvious such and big tires or chrome rims it tends to take a back seat.
FOR 3.5" is designed for exactly what you are describing. I would not waste my money on OME J/L - there is a great deal of literature here on the significant benefits of FOR and Slee 4" over OME J/L, so unless budget is your main driver and you believe you can live with nothing but springs/shocks, you probably will not save money in the long run (even OME advocates like Romer admit they have been through about every version of OME spring offered except the comps, and Ken even has a recent post about trying to level his J/L setup to handle weight :flipoff2:).
For a level stance out of the box that can handle the weight you are describing to run 35's, FOR has everything you need (except maybe an adjustable rear panhard bar).
150lbs on the roof, 200+ lbs gear in the back, 200lbs of me on the tailgate = still almost completely level. When the truck is completely unloaded it sits just about perfectly level as well. FOR uses cold rolled coils, and I believe they are even made in the US (imagine that). I honestly could not imagine a better riding suspension. No, I've never run OME, but I have spent countless hours on here listening to people complain about the shortcomings. You spend a little more on the FOR kit, but you get arguably much better coils and shocks. The way people have to mix and match OME stuff on here seems almost comical to me. The reasoning always seems to be that you can just swap out your OME heavies for J's, or J's for comps. Save yourself the headache and get a kit that flat out works right out of the box. I have also read nothing but good things about the Slee 4" kit as well, so that might also be worth a look.
my truck with the Slee's seems more stable on the road than the one I drove with FOR. Less sway when cornering. Not that it was not something I could get used to but it was an unsettling feeling as I wasn't accustomed to it. Even with my Hannibal rack loaded with sheet goods it seemed not to lean as much. Maybe this has something to do with the progressive nature of his springs.
Off road both trucks rear tires rubbed the frame at full stuff and I really didn't feel there was a significant difference between the two. This wasn't an exact terrain comparison but both trucks are set up very similarly as far as accessories goes. And in both cases when the rear rubbed all four tires were still on the ground so it would seem to be a close comparison.
Thanks for all the feedback and this is where I stand...
I have done some more research over the last few days.
F.O.R. isnt an option since they are on Backorder or at least thats what their site says.
I Want Slee 4" but its not in the budget at this point!
This leaves me with OME which is fine with me but what springs should I buy???
I wanted to do the J's but from what Im hearing they wont work with my current unloaded setup. I do believe I have seen a few rigs with J's that arent heavily loaded but I guess that doesnt mean the caster isnt way out either:doh:
I dont like the stinkbug and rarely carry a heavy load for long and I would like a level stance especially unloaded.
I am doing bumpers but going tube to save weight...
So should I just buy a medium kit or should I do heavy in the front and med in the rear:confused: Please help need to make a decision..
Thanks Jason:)
Jason,
Seeming as you helped me out, here are my thoughts. From everything I read on here I kept going back to the heavy front/medium rear combo. My plans are for the arb deluxe front bumper and sliders, it will be a while until the back gets much weight. I spoke with Slee's shop, I'd give them a buzz, and that is what they recommended as well, h/m. You can always add heavy to the rear later, no big deal. For what my plans were, they told me not to get the J's. Good luck!
Jason,
I had the same setup, minus sliders and plus a 12k warn winch, on my 94, and I loved it. I've got mediums front and rear on my 97, plus the arb, winch, and sliders, and the ride totally blows. I need to upgrade to heavy springs for the front, and possibly look into a better shock option (maybe Frankie's Bilstein's could be used in this application?).
I do not know all, but here is my $.02 worth. After doing the bodywork on my rolled over 80, the guys presented me with a 3" OME heavy lift with 1 1/4" spacer in the front. It was perfect for me with my short wife. But it may not be for everyone.
The reason that they had the lift parts to spare was that they all had ladies who were taller than my bride. They had all started with a 3" lift, and then later opted for the taller versions, the J lift. The 3" lift coils and shocks were laying in garages and were perfect for me.
In appreciation for my bodywork, they offered me a lift kit that was perfect for the short lady who has always been interesting to me.
I know that they all started with a 3" lift, and then found it to not be tall enough. Their brides are taller than mine. They all changed to taller lift suspension. That left the 3" coils available to me.
I have noticed that the 3" or the J coils both handle very much the same if the caster correction is done. If you are paying the money for springs, I would go for height.
I have no problem with lifting my daughter up into my truck. But if my lady had to be carried up to her seat, she probably would not be happy, and neither would I!
If your bride is over 5'3", I would opt for more height for the money and go J spring. The only reason that I haven't is that my barely 5' lady likes to get in my truck without a stool! I second that emotion!
I'm currently running a J front/ Heavy rear. The rear is just slightly taller than the front. I"M currently at the height that Nay has posted for FOR lift. 23.75" hub to flare.
I run 315's and it's a nice height...I'm debating on going with the SLee 4"/J rear or FOR...not sure at the moment, but the comments on a soft ride have me a little nervous as I prefer a slightly firmer ride...maybe the shocks with stronger valving could do the trick.
Of course I"m 6'4" and my wife is 5'11" so I'm not too worried about height. My daughters are pretty tall as well :) and they are only 4 and 6
well i can offer my experiences on MY truck. I ran the J's and L's all the way around on a stock truck and i had the stinkbug and it was a little shy on caster w/ the OME bushing but i believe the slee blues would have been perfect. Now i barely had the slightest grrrr's but only when letting off during acceleration and slight wandering on the hwy. Then i added the slee 4'' spring up front and left the J's in back, still only OME cc bushings. The spring was VERY stiff for an unweighted truck wandering increased but no more grrrrs. I added the ARB and warn 9k and it drove awesome; then i added the IPOR rear and it now has gotten a little light in the steering again. but..............it sits level. my next move will be 4'' rear springs and landplates, but im in no hurry.
My vote under your circumstances posted last would be the J front and Heavy rears, especially if your bumper slider builds will be done by end of this summer. I like the Heavy/medium combo idea too but i think youll exceed its offerings and want more lift after the goodies. trdparts4u had a couple J kits on sale for 530 w/out bushings.
every truck being a bit different you may get into driveline vibes w/ the J's but seeing as how they are almost out of range of bushings, pick a plate design to have as a backup. and i believe youll see them go away w/ weight.
I have been running OME heavy fronts and med rears for a while, ARB but no winch yet and ome castor bushings. i am only running 305s but i couldn't be happier with the ride and no wondering at all after i put the bushings in. now all of this could change when i put my winch on in a few weeks, but for now i am very pleased both offroad and on. i also pull a fishing boat or fourwheeler and trailer almost every weekend and it sets very level under this load and only very slightly high in the rear with no load.
FL80ADDICT,
I have almost the same setup as you do, with pretty much the same future mods planned. I'm running OME J's & L's with OME castor kit and 315's, and the only things weighing it down are front bumper, rear bumper with tire carrier and a 255/70 tire, and it sags too low for my taste. Overall lift now that it's settled seems to be 2.5"-3".
If you thinking about drawer systems and a 12000 lb winch (I wouldn't go 9500, 80's weigh too much), and want 3"+ lift, I'd go with OME competition series 4" springs (OME419 & OME422), they're only 5mm longer than J springs, and handle the extra weight better. And L shocks seem to be ok with them, I've seen others on the board with comp springs/L shocks combo.
My $0.02, hope it helps!
Interesting you saw frame rubbing. I have never had any rubbing with the F.O.R. and I run a big 35" tire.
I think if the F.O.R. kit adapts over time you will see these exact same springs with a Bilstein shock more in the 360/75 valving range. I have expressed privately to a number of people asking about F.O.R. that if I think anything people will think it is too soft. But then, some may think a nice riding heavily loaded Slee 4" is harsh unloaded. We hear this even about the much lower spring rate OME heavy suspension.
As to buying OME, I woudn't, personally. Not because it is bad, but because Slee 4" springs don't cost any more, and you could run them with OME shocks just the same way you run J springs. You don't have to buy the whole kit.
The Slee 4" fixes the one thing that isn't great about OME - the springs. OME makes a very good shock. I like Bilstein better apples to apples having run both in two different applications, but that's not huge. Everything beyond springs and shocks is standard to the lift height, and OME J/L is not a complete kit.
I have to say that if I was going for 35's and I couldn't buy F.O.R. due to availability I would buy the Slee 4" springs and match them to 5100 series Bilstein shocks with eye adapters in a 255/70 valving with an adjustable rear panhard and blue bushings with LT template for caster. I'd drop bracket my brakelines an inch and call it a day. You'd be not much more than a grand into it with an extremely nice setup that would substantially outperform a similarly priced OME J/L setup.
Actually, I would go Bilstein 7100's with those springs and spend a few extra hundred and get what the 80 really needs in a remote reservoir rebuildable high end shock. In fact, this is exactly what I will be doing in a couple of years to really complement how good the F.O.R. springs are. You get a spring that handles load this well without ride harshness across the load range and add serious shock capability of a 7100 and I think you are getting close to 80 series nirvana.
I think that is some good advice.
The ONLY thing that I"m not sure on is the 4" rear. I know mine sat just slightly rear higher with 4" front/J rear. I think the 4" rear might cause stinkbug if you aren't heavily loaded.
I really like the performance of the Slee 4" and J rear with OME shocks...was a good combination.
