Ha-ha! Hence the core exchange when getting another trans.I‘m not sure how accurate this but Car Care Nut on Youtube stated that the reman Toyota/Lexus transmissions have all new internals. The only part re-used is the case.
Greetings all! Same story as everyone else! Bought a 2011 Lexus GX460 with 105k. Drive in warm conditions and amazing! Temps dropped here in CO and started throwing P2714 and P0761 after the first 5-10 minutes as it can’t shift past 3rd gear. If we pull over, erase the codes and restart, it’s like nothing ever happened. Super frustrating!!!!I‘m not sure how accurate this is but Car Care Nut on Youtube stated that the reman Toyota/Lexus transmissions have all new internals. The only part re-used is the case.
2012 GX460 which I purchased 2.5 yrs ago with 140k on it. Now 175k. Only problem was transmission would shift slowly when cold, 500 RPM higher.. Say 40 degrees or less on the temp..Greetings all! Same story as everyone else! Bought a 2011 Lexus GX460 with 105k. Drive in warm conditions and amazing! Temps dropped here in CO and started throwing P2714 and P0761 after the first 5-10 minutes as it can’t shift past 3rd gear. If we pull over, erase the codes and restart, it’s like nothing ever happened. Super frustrating!!!!
Reading across all forums online for Lexus and Toyota and especially GX460s, seems like this is all a mystery and no one has an answer. A shop did test the solenoids and they were ok, we did get the fluid checked and replaced, so now it’s either replace small parts at a time or do the full swap…. We are keeping this one until it croaks, just sucks no one has info on it yet vs. replace.
We’ll update once we make a decision, but for now getting in the habit or the old erase engine codes and restart every morning. Super odd as to me, seems like it would be a fluid temp or pressure issue that needs to build up. Oh well.
Cheers!
My saga is earlier in the thread... Started getting codes at 168k with ZERO drivability issues. Changed the fluid three times with a short neighborhood drive in-between and it went south... QUICK. If I had it to do over again, I'd likely change the filter with each of the fluid changes but I'm not sure if that would have made any difference. Best of luck to you; they are awesome machines. IF my wife gets the LX she's always wanted, I'd be happy to give up my taco and take the GX.Please comment if you if you have changed at high miles.
And @Acrad - Yup! Those are the codes and nothing we are doing changes things. Worse when colder and always first thing in the morning. Once we clear the codes, everything is fine. Likely why resting the solenoids showed no issues.I'd like to say "congrats" on your GX, but I may hold that till you run down your issues.
Is there anything that your doing that causes the codes to trip and is repeatable?
Will do!!!Hoping that works for you. Make sure to let us know.
Not sure what you mean by, "... final filter and fluid change." Are you selling, don't think it'll last long enough to do another change or your done changing out filter and oil?With all this info, I'm dragging this back to life because I've got 190k and about 5 fluid drain-fills at 180k, so fairly fresh fluid now (no history of previous fluid maint). No problems yet. But I have the filter, pan gasket, and fluid to do a final filter and fluid change. After reading these issues I'm thinking the best thing is to leave well enough alone? See how it goes? Or it doesn't matter and a fresh filter and fluid will only be good for it?
