Clear as mud. Again, my retired engineer mind wants tables of data, not lore.
So how do we cross reference the Lexus credit card fob for the LC it will work with? So far, I haven't found a table that shows that. Can we assume that a 570LX of a given year will work with a LC of the same year? And, where did you do your lookups and cross referencing?
There is no table. It requires some online research and conclusions. The 2010-15 LX will work with the 10-15 Land Cruiser, I've also confirmed that the 16+ appear to all be the same between the LC and LX ( confirmed on a 16 to definitely work).
I looked at Toyota Parts sites, remote sites, and even
Ebay to cross-reference and confirm. And after all that, I was pretty sure I had the right card ordered (and I did). So if you have a 10-15, FCC ID: HYQ14ABB should work for the credit card (again, I confirmed on a 11, but it appears the FCC ID/FOBs are the same 10-15. No idea on 08-09. Someone will need to research it.
For a 2016+, HYQ14CBB will do the trick. I'd recommend ordering from Norfolk or another Toyota dealer where you can return if it won't program, but I have put in the work to confirm what works on a lot of years. Also, if you buy a pre-owned key, you must have Toyota or a locksmith unlock it before programming. Techstream will not unlock the key, and I have no idea how it is done.
If your Land Cruiser spare has a double sized emergency/entry key, the Credit Card style emergency key will not work, as it is single sided. The FOB will work fine, but you won't have an emergency key to get access to your rig. I carried a spare battery in my wallet in small plastic sleeve when I had my 11 (which had a double sided key), but never had an issue. The LC will tell you when the FOB battery is getting low.
The 2016 has a single sided key and my local locksmith was able to cut it with no issues.
