Lets talk hitches....
Something of note that I'm encountering now...
On stock suspensions...
Receiver height on an 80 with factory hitch is ~16"
Receiver height on a Drawtite is ~18"
Punch a hole as low as possible through a Slee rear bumper and the factory cross member and weld it to a 2.5" square tube cross member welded to the frame on a truck with a 2.5" OME heavy lift and 33" tires and the receiver height is 26".
From what I can tell, typical trailers vary a lot. The range I've seen is around 12" (small) to ~17" at the coupler.
So, I'm on the hunt for a Class IV, 10,000 lb ball mount in the range of a 12" drop.
So, those of you running 6" lifts on 37" tires with through the bumper receivers... Did you custom make the ball mount too?
the bottom of the hitch receiver built into my 4x4 lads bumper is about 27". I use a 6 inch drop hitch because i didn't trust the bigger drops I saw. the resulting rake on my boat trailers is there but really pretty minor and trailers handle fine and launching is easier ;). just need to be sure to remember to bring the outboard's leg up ;)
I doubt this will work since we weren't able to fit the kart in our old Previa without removing the roll cage :doh:
Besides, where would we put the kids? (3 girls, 3 boys, 3 dogs)
Remember that you can add a seatbelt to the middle of the 3rd row so all the kiddos are buckled in :cheers:
x2 on the small trailer for the cart.
If you have a reese hitch or drawtite etc using 6 bolts to the frame then maybe.
That rear crossmember is strong and triangulated well but I would not trust it with that bouncing around.
I've done stuff probably heavier than your 150lb kiddie kart on hitch carriers. I wouldn't worry too much about doing it if you use a real hitch - like an OEM one. I personally wouldn't waste my time with anything less if you're going to carry like that. Biggest problem with those things is they rock back and forth. Nice thing thought is you don't have to mess with a trailer while traveling.
Yeah, I'm pretty sure I'll end up with a Class 3 and be done with it, but I'd like to get one that has the most ground clearance...
Anyone have comparison shots of the Valley, Reese, Hidden, Curt, Draw-Tite, etc. using the OEM bumper?
BTW, the front setup looks good, but that's where I plan on putting my motorcycle ;)
Sorry to hijack, but really?
Do you mean the 2nd row (middle seat)
Do you have a link to an article/thread?
I did a little write up when I put the DrawTite on my wife's truck. Stock suspension, OEM bumper & covers, spare mount, etc... Class III/IV hitch.
https://forum.ih8mud.com/showthread.php?t=104627&highlight=red+hitch
It does not hang down as far as the 'factory' receiver, but it does stick out a bit. It has to in order to get around the spare and have enough length for Class IV ball mounts I think.
YMMV
The 3rd Row middle seat in the 95-97 that doesn't have a seatbelt....
From what I've read, the 2nd row center seatbelt part is a direct bolt in for the one missing in the 3rd row seat :cool:
Got it, thanks.
I thought you meant a shoulder belt could be added.
The lap belt only works with a baby seat (or a consenting adult :D)
Dang, must be a buch of midgets, I can't imagine putting three of anyone big enough not to be in a baby seat back there.
The '92 we had was an 8 passenger. Don't count on putting 3 back there unless they are old enough to not need a child seat and small enough to still fit. Child seats fit back there for us, but only 2 of them. The rear facing will likely require removing the 2nd row headrest.
A configuration that worked well with 3 adults and 2 kids was to put the child seats on the PS in rows 2 & 3 and the third adult (taking care of the kids) on the DS row 3 with the 2nd row DS folded forward. We did this for a 500 mile trip when my twins were still little enough to be rear facing.
Loading the lucky guy in the 3rd row through the back hatch was interesting.
For going out to eat one night we put the boy's forward facing seats in the 3rd row and my niece in between them (she had just graduated from a booster), 3 teenagers / adults in the 2nd row and of course 2 adults in front. Yes, you can put 8 people in an 8 passenger 80. Don't plan on going very far that way though.
IMHO and YMMV as usual.
