- Thread starter
- #221
So I clearly have some sort of alignment problem:
This is the DS front (obviously front right…?) tire. The PS wear is fine.
If the pics don't show it, the wear on the inside of the tire is radically faster than the outside.
I would guess that I have a toe-in problem - or is it a camber problem?
Is this a clear-cut case of needing to get back into the knuckle and install the proper shims - that's the camber adjustment, right?
Or maybe as simple as correcting the toe-in with the tie rods?
I did the alignment by the driveway method - mark the center of the tire on both sides (i.e. 180* of rotation), measure from point to point, rotate the tires, measure again, adjust tie rod as necessary to be within specs. Did this with wheels off the ground first (for ease of rotating back and forth, measuring again, etc) then with the truck on the ground and weight on the tires. I haven't remeasured this yet but given that the bad wear is strictly on the DS tire I am guessing the issue is not alignment. But I'm not an expert so perhaps the PS tire is tracking correctly and pulling the DS along with it?
The steering doesn't feel terrible. There's some understeer (i.e. once the wheels are set into a turn they will tend to follow that path rather than trend back toward straight) and it's not as crisp as my new(ish) VW but…what'd'ya expect right? Im most concerned with the uneven wear. Granted this will get me some new (bigger) tires
but I want to correct the issue before dropping $$ on new rubber!
Thoughts? Advice?
Thoughts? Advice?
