The 9w don't put out 3x the light of the 3w... they are brighter but not by a whole lot. That said I would use the 9w unless I was intentionally looking to not be so bright (close lighting like in the glove box etc)
Did you wire these up with a hood switch or a regular two position switch?I put 2 mounted to the underside of the hood too... lights up the engine bay pretty well.
Looks pretty funny out in a field at night with the hood, rear hatch and doors all open... like a spaceship.
Lights look pretty neutral in color... maybe a little towards "led blue/white" but not much. I HAVE touched them after they had been on for a while and didn't notice anything...
I positioned them specifically so light would spill out onto the slider and ground. I am thinking of adding a couple to the doors themselves, both for the additional ground light and the safety of others to more easily see the door if it is open.
Perfect! Thanks so much!Size of a nickle, maybe a little smaller.
Mine are run from an aux fusebox I installed in the pass rear quarter. I have grand plans for all sorts of lights and do-dads back there which is why the aux box is there.
