LED Headlights Anterna RF interference
I just had LED headlights installed in my 97 LX450 ( not sure which mfg) and now my stock radio FM reception screams when I turn on headlights.
Suggestions?
Forgot to mention
Power antenna (aftermarket) was replaced at the same time
Could it possibly not have the antenna lead properly connected?
Did the antenna lead get cut & spliced when the new antenna was installed?
LED drivers can cause RF interference. Sometimes it's just a bad driver. Other times it's a poorly designed/manufactured driver. I tried ferrite core chokes on the wires going to mine to no avail. From everything I've read, shielding isn't possible either because the entire driver and diode would have to be shielded. Some of the noise can be caused by oscillating frequencies used to make the chips give off more light. Since most of the LEDs are assembled in outside the US, they don't meet US RF noise requirements.
Thanks for your insight bmac
What did you end up doing
Abandon radio use?
For the most part at night anyway. A few strong stations are ok with my headlights on. New headunit with bluetooth to stream from my phone is on the list.
The interference is from the DC : DC current regulated LED driver inside the light housing. Most of the interference is on the cable from the light going to the harness/battery. Not much you can do, most are designed with no thought on EMI. I've designed some vehicle specific LED drivers (high power LED arrays) and evaluated some competitive products (even Rigid's) and they generate a lot of noise on the DC power cables.
That noise radiates (cables act like an antenna) and your radio reception will be very poor to non-existent. Basically the noise causes the SNR to drop so only strong local stations can be received.
The MIC lights are even worse since little to no attempt is made in their electronics.
Anyhow, it's a fact of life with LED lights where no or little effort has been made (more $ spent on filtering components and PCB layout) to reduce EMI.
On one custom design my customer can now wrap the power cord going to one of his LED lights around the FM antenna in the vehicle and weak stations can still be received. Took a fair bit of re-design and re-layout work along with using a spectrum analyser to identify the emissions and to implement design changes to reduce the EMI.
Short answer is that LED lights are typically noise generators when it comes to radio reception...
cheers,
george.
cheers,
george.
George
Did you try or consider a capacitor across the input voltage of the LED psu and another capacitor across the ouptut of that psu?
Weird?
I have LED headlights, LED light bars, LED marker lights, LED tail lights, and LED reverse lights and I have zero problem with the radio, and I even have a stock antenna mast that is bent at a 45 degree angle because of a tree. Lol
Weird?
Only my headlights do it.
Weird?
What manufacture/model headlights?
You have NO interference problems when headlights are on?
Thanks
