LED Fubar....
North GA
'97 LX 391K
Really frustrated right now. I ordered low light LED's and followed the instructions based on one of the videos on the site. Replaced the 4 cluster lights and plugged everything back in. Nothing. Reversed how the lights were plugged in, nothing. Replaced the LED's with the old standard bulbs I removed, plugged back in and nothing. WTF :mad:
Fuse under dash is not blown.
Do I have the wrong light? Why won't the old lights work now? How can I tell what position they should be plugged in (into the base)?? If one is plugged in wrong does it prevent all the others from working?
I'm a bit perturbed :bang:
Put a 9volt battery on it and see if it lights, note the polarity, it's on the side of the battery.
The led says right on it 12 VAC, you've got 12VDC. Big difference
I'll give them a call but I ordered 194 lights just like the thread said.
Still confused as to why the old lights I re-inserted don't work either.
I have the 194 LED's.....they don't work. Re-installed the original bulbs and they don't work either.
The 194's are directly from an LED thread stating the same type of light. Maybe try one at a time? Or do they all need to be installed in order to work?
If you have put in the original bulbs and nothing lights up then something is wrong in the connectors etc ASSUMING fuses aren't blown.
Got a meter? Measure and see if you get any voltage going to the original bulbs - if you can connect things up while probing with the meter.
The bulbs should all be in parallel, get a meter and ohm from one bulb to another to verify they are in parallel (with power removed).
AC LED 'bulbs' just mean they've put a diode bridge so that the LED gets the correct polarity regardless of connecting +/- to one terminal or the other. So, that is NOT your problem.
Your problem is that not even the original incandescent bulbs work - resolve that issue FIRST.
By 'cluster' bulbs do you mean the backlight of the instrument panel or what? Dimmer bumped all the way to low/off?
cheers,
george.
Pic of 4 lights I'm trying to replace; not knowing if the new or old are in parallel could be the issue. I'm going to pick up a meter today.
They WILL be in parallel... just follow the blue lines (under the blue mask are the copper 'traces').
cheers,
george.
Figured it out! Hopefully this will help someone else too.
Do not unhook your diff and dimmer switches. I did this because it was difficult to move the plastic piece all the way to the left without stretching the wires. Actually you can unhook them just make sure you reattach before trying out the lights.
I hooked my dimmer and diff lock switches back up and my LED replacements are working :doh:
Yeah, that elektrickery is funny - not wireless...
Lesson 1: Always suspect everything that you have touched/unplugged/moved etc
Lesson 2: Watch out for Murphy when he voids Lesson 1.
cheers,
george.
I learned that when I first took apart the dash. Now I keep a spare dimmer around for testing so I don't have to take the stock one off the panel.
Was just going to ask you if your dimmer was hooked up.
LEDs cut out if you turn it down.
I did the exact same thing, but quickly figured out dimmer had to be plugged in.
Dang it! I was going to suggest you check the dimmer(rheostat)
