When I bought my 2nd LX last year I knew I had some leaks to deal with since the carpet was wet and there was a nice moldy smell going on.
Doors and sunroof were easy-replace the seals and wipes. I then removed the two rear sliding windows, cleaned them up, removed oxidation from the aluminum frames and re-installed them with what I thought was a good seal. I removed and welded shut the port roof rack holes when I had the headliner out. I also re-sealed the rear wing mounts as well as determined that the sunroof drains were open. I pulled the waist trim below the rear windows and siliconed the clips before putting them back on-I even then went on the inside and put more silicone on each hole.
All this and I still had wet carpet in the back-really wet-like get the shop vac out if it rained and the LX was not in the garage. I even had the water pooling in the bottle jack holder issue mentioned by others here.
I have new one piece glass and new rubber seals (like the clean look) so I removed all the trim in the back and started chasing the leaks down. With the garden hose dumping water on the roof I found the leaks to be from the pinch welds that hold the rear windows.
This is from the inside looking up, inside sheet metal in on left. On right you see the sound deadening applied to the outside sheet metal. The outside body meets the inside between the red lines and this is the point of the leaks on both sides. I guess the water is running from top, around and under the rubber to get to this point. I have the same issue with the rear hatch glass but that has a non-oem seal that looks too small and was not put in with any kind of sealant.
I have removed the rear sliding windows (they are for sale now) and am ready to put in the new glass.
What do I do about the leaks? How do I seal them and not impact how the new window seals go in?
What is my best option for a sealant for the glass both between glass and rubber and rubber and body?
Obviously silicone sealer that I used the first time is not right.
