Just diving into my first cruiser. 97 LX450. Tearing drivetrain out for a 1HDT swap and finding this leak. Any guesses from this mess whether is the PS pump/gearbox or other? My hunch is gearbox, which will add to my todo list
Yah, I agree, tough to tell in the pictures. I guess here, the vast majority of the crud is on the gearbox, but it is slung all over the place. Will clean up tomorrow when I get back at it. Entire front clip removed now so at least access is good [emoji14]
Lots of leaks, but the gearbox is pretty much the only thing staying.
Well-then your task is easy. If you are contemplating a huge swap, than the $200 to rebuild the powersteering gear box is trivial. Most need it, or will soon. You should rebuild it since it is likely it's leaking, and you are already suspicious. Your peace of mind when done, will be worth the $200 cost.
I bought a rebuilt steering gear from Cruiserparts.com. Paid $400 and it comes with a 1year warranty and no core charge. I've ran it about 1k miles with lots of rocky wheeling and no problems yet.
I have seen this and fixed it several times. Its the front main and oil pump cover. Look at the bottom of the engine, It Is most likely dripping with oil from those 2 buggers. Dizzy o-ring can contribute as well but It usually soaks the ALT and yours does not look like what I have seen when there leaking bad. People usually say they are filling there P/steering reservior often If hoses are bad. Or there spraying Like a fountain...!!! LOL I had one Cruiser that was covered with oil all the way back to the spare Tire, Valve/C gasket was bad too though that added to the mess. Good Luck..!!!
