Leaking Fluid 94 LC
Help!! Leaking Fluid 94 220K
Got back after a day with the family and noticed a few ponds under the vehicle. One right near the center where the firewall, where engine meets tranny and a few others towards the rear. The fluid looks clear but is slippery like brake fluid. I looked underneath and most of the undercarriage is soaked from the tranny back which is why there is fluid near the spare tire. I don't see any visible leaks near the brake booster or reservoir or abs location. It looks like it starts somewhere near where the tranny hook to engine. It is clear fluid not dirty. I did notice the brake reservoir is lower this morning just under half. No warning lights have appeared on the dash and the brakes feel fine, no squisy pedal. Any ideas could be causing this?
Power Steering
I'd check your power steering. My 94 did the same thing with the same look. Your pump/hoses/connections may be leaking.
If not water from the A/C (clear but not slippery), then you got gear oil (Mobil 1 is clear) that is slippery but has a strong smell, you got brake fluid that is clear, but not very slippery, and you got power steering fluid, which usually is red (Dexron ATF spec) unless someone used generic power steering fluid instead, which is usually clear. Power steering leaks often blowback along the side of the engine and along the tranny cooler lines, dropping near the rear of the engine, front of the tranny.
Definitely check all the fluid levels, but also, reach up and touch the fluid that is leaking and smell it, compare it to the other, etc. The power steering fluid, if using Dexron ATF, should be red, unless very old (brownish) or some other type of fluid has been used.
Not everyone uses ATF for their Power Steering. I don't. Just didn't want someone to take it from your post you should put ATF in there rather than could. I prefer synthetic Power Steering Fluid.
Thanks
Hey guys thanks for the speedy reply. I washed her this morning and hosed out the garage. I let it get up to running temp and pumped the brakes and watched. I saw no visible brake leaks. Although the fluid is almost on the "min" level" so I am going to top this off and see if it falls. I will also inspect the powersteering pump. I checked that fuid while running and it was actually bubbling up out of the unit while running. Is that normal? It looked red like the dextron. I just bought this truck so I don't know what they put in it.
I keep you posted!
M/C
I was just checking the fluids. The only one that is low is the brake.
After smelling and checking the color it seems to be brake. I noticed right below the black circular vacuum chamber that the m/c bolts into, that fabric right on the firewall, is wet from fluid. Could the m/c have leaked and then not continue to leak?
Was the lkid on the res tight? Could have been at a steep angle with a loose lid and fluid leaked out (Best case)
Clean it up, top it off and check it everty day to see if you can identify any leak.
thanks again
I washed everything well and the lid was on tight. The only thing low was the brake fluid. I did not check diffs but there was no leaking around there visible. So I am topping off brake and will see if any spots appear. I'll check it every time I drive it and keep you posted. The Pwrstr pump looked ok onthe rear seal as well. Thanks again for all your input. This is my wifes daily driver so I want to wrap up this asap. Any thoughts on the best brake fluid to use?
Found Problem
Well, after cleaning everything down and driving for just about 7 miles, I found the problem. Temp gauge started to rise and I stopped to find steam coming from the hood. Have not determined exactly where the leak is or what hose it is but it is in a tight spot behind the manifold right near where the tranny and engine meet. Lots of water everywhere there and back. Thankfully not the brakes but just a hose somewhere in there. The guy I bought it from said all the hoses had been replaced but I guess that was just convenient hoses. Anyone know of a hose back in that hard to reach section or is this the PHH described elsewhere?
Havent done mine yet, but I believe this is where the PHH is located, driver side, tucked back in under there...
It is located below the intake manifold toward the rear of the engine, DS. If you look down from above in strong light you should be able to see a pinkish stain running down the rear DS of the engine. Very difficult to see the hose itself, which is only about two inches long. Ditto if you look in and up a bit (above the starter) from the DS front wheel well. The FAQ's area covers how to replace it. If you decide to take it to a dealer, ask them if their mechanic knows the quick or "cheat" method. Which is the method used by mudders. Reason you want to ask this; the FSM method to replace it requires removal of the intake manifold; usually somewhere around $800+ in labor charges. The cheat method (at a dealer) will cost around $250-300; really depends whether the mechanics have done it before that way, and if the service writer will write it up that way.
Many thanks!
Hi Gray I actually had it flatbedded to a dealer today figuring I c ouldn't reach that far back there, but maybe that was a bad idea! :confused:You mentioned the FAQ's area covers how to replace it. I tried to find this section but don't see it when I click ion faq on the menu? above the thread.
"Which is the method used by mudders. Reason you want to ask this; the FSM method to replace it requires removal of the intake manifold; usually somewhere around $800+ in labor charges. The cheat method (at a dealer) will cost around $250-300; really depends whether the mechanics have done it before that way, and if the service writer will write it up that way. "
Thanks for the tip, but what exactly is the other way if they don't know? Weld pipe over it?
Thanks!
Got It
I got after review a few threads. Bypass the pipe hose and use a longer durable hose I presume.
Here are a couple of links that talk about it. Most DO NOT by-pass it; that is a super cheat method; not recommended unless ie: you are stuck on a trail.
The "cheat" method (this term is sometimes used by mechanics as it does not follow the factory service manual exactly, but achieves the same result and usually saves time) involves disconnecting a metal coolant pipe that runs from the back of the engine near the top of the firewall down to the DS of the engine, twisting it, and then while working through the DS wheel well replacing the 50mm section of hose that runs from the end of that pipe to a nipple/port on the side of the block.(more complicated than this quick overview)
The Slee link below has good pictures that will help give you reference points. The first thing you want to do is to ask the service writer if they have a mechanic who knows about and has used the alternate method without removing the intake. Tell them that you have been told that it takes just an hour or two by someone who knows how to do it (true). If you get a bad service writer who won't do it this way, you may be screwed; if there is another Toyota dealership (other than where it is now) you could also give them a call and ask the same question.
Slee - PHH (Toyota 80 Series Land Cruiser)
https://forum.ih8mud.com/80-series-tech/6994-phh-2.html
'Course we never even identified where the leak was; we're just runnin' with it... :rolleyes:
Yotame, I honestly wish you the best of luck, but no way would I have shipped it off to anywhere till I knew EXACTLY where the leak was. I mean c'mon; how hard is it to poke around until you say, "Ah ha. So THAT'S where it's coming from!"?
Seriously though; I do wish you all the best. Please keep us posted.
Curtis
Well when I made that decision I was overheated at a local exxon station. That mechanic there told me there was a 75% chance he could fix it but that it looked tight and he might have to take off the manifold etc.. and I had to wait 3 days to get to it. I figured the dealer has a better idea of how to do that and maybe a special tool etc.. that could be faster also my wife has been putn the heat on me to get the aligned at THE DEALER so I caved and just sent it there. If I had been able to identify it while it was still in my garage I would probably tackled it.
Thanks for the links. Keep you posted as to damages.
Ditto; the discussion/advice was assuming it was the PHH based on the description; it potentially could have been a heater hose at the top of the engine behind or above the valve cover/engine. Only thing to do is to look for the leak. The dealer will find it I'm sure, question is, how much will it cost you.
Sorry for the delay in following up. OK so took it to the dealer to get PHH fixed. Told me they wouldn't fix it w/o replacing the tube because it looked corroded. I said ok. The cost was to be $625 for all that. Also requested an alignment. Took a week to get 3" hose part. A week later I picked it and found out they couldn't do a full alignment because the tie rod ends were seized. So they refunded this fee after I challenged it since they never did it! Drove to my office and checked on it an hour later and there was a huge puddle under the radiator. Inspected under the hood and saw the small hose on top of the radiator had been cracked and repaired with epoxy which didn't hold under the heat. So the radiator was leaking once it got hot. I called dealer and said they need to come tow it back and try to fix it or get a new radiator. They checked it out next day and after trying to reepoxy the hose over the weekend said it would need a new radiator at MY COST. I said BS! They replace the radiator. Took a week to get that in.
They also insinuated that the radiator was broken when it came in the first time. I said BS and that the mechanic probably clipped it trying to get the PHH out! Which he later acknowledged! I also talked to the tech who also told me the he didn't have to replace the tube from the initial repair. So I had that refunded as well. Now it's finally over. I have a new radiator and coolant, PHH and a slightly better alignment for $400 and it took two weeks and lots of headaches.
