Leaking Fluid 94 LC
Sorry for the delay in following up. OK so took it to the dealer to get PHH fixed. Told me they wouldn't fix it w/o replacing the tube because it looked corroded. I said ok. The cost was to be $625 for all that. Also requested an alignment. Took a week to get 3" hose part. A week later I picked it and found out they couldn't do a full alignment because the tie rod ends were seized. So they refunded this fee after I challenged it since they never did it! Drove to my office and checked on it an hour later and there was a huge puddle under the radiator. Inspected under the hood and saw the small hose on top of the radiator had been cracked and repaired with epoxy which didn't hold under the heat. So the radiator was leaking once it got hot. I called dealer and said they need to come tow it back and try to fix it or get a new radiator. They checked it out next day and after trying to reepoxy the hose over the weekend said it would need a new radiator at MY COST. I said BS! They replace the radiator. Took a week to get that in.
They also insinuated that the radiator was broken when it came in the first time. I said BS and that the mechanic probably clipped it trying to get the PHH out! Which he later acknowledged! I also talked to the tech who also told me the he didn't have to replace the tube from the initial repair. So I had that refunded as well. Now it's finally over. I have a new radiator and coolant, PHH and a slightly better alignment for $400 and it took two weeks and lots of headaches.
A better reason to start working on your own truck cannot be found. You know it gets done right. Some yahoo poking, pulling, prying at stuff under your hood. Who knows what else was loosened up, cracked, bent, etc....Do it yourself or find an independent shop you trust for future stuff. You coulda had that PHH off and a new one in during a long Saturday afternoon. Probably rebuild your starter, replace the fuel filter and throw in a new thermostat while you were at it without too much trouble. haha, or that is my plan anyway :D
