My 1976 stock FJ 40 runs pretty crappily. The engine surges, and runs better when the choke is out after it's warmed up. It has a leak around the intake manifold at the gasket. I should say gaskets, as the PO sandwiched 2 of them under there. Being a newbie when I bought it, I didn't know the difference, and it ran fine for a while, but now it doesn't. When I spray starting fluid around the gasket the engine surges momentarily, so I know it's leaking. Question: What do I do to fix it? Should I take out the manifold and have it machined flat, or just try to get another one? Could the block be warped as well? If so, is that fixable? I probably won't do the work myself, but just want to know what my options would be.
