Leaf srping u-bolt plate
Montreal
Leaf spring u-bolt plate
I was riding this weekend an didn't see a rock in the grass "typical" i guess, i almost went throught the windshield. What you guys do to put some kind of a ski so rocks slides. Is there something someone sell?
most people go a ubolt flip. do a search as there are articles on it. but the basic process entails putting the plate on the top side of the axle. It still means you can snag the ends of the ubolts on something though. A 'ski' sounds like an interesting idea, but i don't know how you'd go about implementing it.
http://www.sor.com/shared/image/290-68_i-big.jpg
There are u-bolt skid plates. Click the link for a pic. Whether they are better than flipping the u-bolt, I dunno. On the one hand, they prevent anything from striking the u-bolt. On the other hand, they project down much further than the bare u-bolt would when flipped. I'll leave it to others who have actually run them either way to comment, as I'm interested in one of these solutions myself.
rusty_tlc said:
Mine look a lot worse than that. They will take a lot of abuse.
I'm sure they will, but i won't :doh:
my64fj40 said:
Then there are also ubolt flip kits out there
You can do that even if you are spring under axle?
Hi All:
Yes, the stock u-bolt plates can get really beat-up.
For alternatives, there are what I call the "rock toboggins" made by Con-Ferr and sold by many venders. These actually hang down lower then the factory u-bolt plates but protect the u-bolt nuts from damage.
Land Cruiser Advance Handling (LCAH) of Albany, Oregon sells some low-profile u-bolt plates that move the u-bolt nuts along-side the spring packs, instead of underneath, for better ground clearance. I have been running a set of these for the last few years without any problems.
Man-A-Fre sells a u-bolt "flip kit" which moves the u-bolt plate above the spring pack, for more ground clearance, which is an excellant idea.
The "rock toboggins" are the cheapest upgrade u-bolt plates, while the M-A-F "flip-kit" is the most expensive. As always, one usually gets what one pays for!
Regards,
Alan
I will say that the man-a-fre is not that cool... the shock mount on the rear spring suck and will not work... this is more true for E-75 trucks than post 75 trucks. but the post 75 set up put the shock in harms way.... i think that this is the best part out there for the job but do know that you will have to make your own shock mounts
Josie'sLandCruiser said:
Hi All:
Regards,
Alan
I'm definitely a fan of the u-bolt flip. I had the ones from Man-a-Fre on my 40 and loved them. Much better clearance and very stout. Also slide over the rocks well.
Not a closeup but you can see them in this pic.
