Leaf spring help -
Austin, TX
I've got a set of 4" Skyjacker springs on my 40 that are so stiff my other half calls it the kidney-shaker, needless to say I'm trying to rectify. My shackle angles are pretty good and the pins/bushings aren't over-tightned, so all I can figure to do is remove a leaf. I've been searching for a while here and think I'm supposed to remove the bottom leaf, does this sound correct? Is it just as simple as clamping the springs, loosening the center pin and removing the leaf? Should I replace the pins? Anything I'm missing here?
Never messed with leaf springs other than replacing them ...
Tucker
Basically most 4" springs are not going to flex much and have a pretty stiff ride. You can probably help them a little by "working" them alot by driving through spots like your pic shows. Sounds like your shackles and bolts aren't much of a problem since they are loose. I've seen leaf springs (my waggie springs come to mind) that have plastic pads at the ends of each leaf so they slide on each other better. Also, I've seen where people will disassemble their spring pack and paint them with tractor/farm paint called "slip paint". It is really slippery and tough and will help for a little while till it wears through. It will allow the leaves to slide on each other better than they are now.
Tire pressure will make a big difference...might be a cheap and easy option for the kidney problem.
Edit: just noticed your shackles are too short for lift springs. They are inhibiting your suspension travel. The more arch of a spring the longer the shackle needs to be to deal with the lenghthening of the spring when it flattens out. Don't use the kind (confer) that have a reinforcement welded in the middle...seen this hit the shackle hanger on a friends 4" lift cruiser...pretty much defeated the purpose of longer shackles.
I agree with most everything you said. Would you please explain this part?
If its a 5 or 6 leaf pack you will probably have to remove a leaf from the middle to notice a difference. Removing the bottom leaf probably won't make much difference in the spring rate.
The steps you described to remove a leaf is correct but you may also have to "open" or bend the clamps to remove a leaf and then rebend them closed once done.
Replacing the spring center pin bolts is a good idea.
FYI, Some folks say not to reuse u-bolts. If you do plan to reuse them and since you have SUA, make sure the U-bolt threads are in good shape before removing the nuts. The threads are prone to getting damaged from off-roading when SUA, then when you loosen the nut it destroys the threads.
Definitely air down off road, but can't really in town :frown:
Hmm ... I'm running stock length shackles w/o a cross bar, does anyone make extended like this?
Tucker
i just cut the centers out of my warrior shackles because the center piece hit the springs so it would not swing out,now it rides like a dream.
What would an approximate length be for the 4" springs, or could I try and calculate a certain angle for the shackles?
Tucker
Measure the eye to eye distance of the spring at full droop and at full compression. Pick a shackle length and angle that will accomodate this range of spring movement w/o allowing the shackle to invert plus a little extra to make up for error.
Tucker
Most places make 1.5 inch and 2.5 inch extended shackles. That would be a good starting point. If your shackles are stock, they are 2.75 inches from pin to pin. You can see different shackle sizes on SORs website at the bottom of this page - http://www.sor.com/sor/cat288.tam?xax=11915&page.ctx=cat288.tam
Pretty easy to make. I stopped by the local metal place and had them cut 3/8" X 2" in 6 inch sections. I then drilled holes where I wanted and put in new 5/8" bolts and bushings. I made mine 1.75" longer than stock just to get my back end sitting level due to sagging rear springs.
Just remember, with longer shackles up front, you will probably need castor shims.
Good luck! :cheers:
Quote:
I agree with most everything you said. Would you please explain this part?quote]
As the spring flattens the shackle pivots towards the back of the rig and and the bottom of the shackle starts to "arc" upwards. It is at this point where the reinforcement in the middle of the confer shackle was hitting the stock shackle hanger on the cruiser frame. The 4" springs are considerably longer than the stock springs when flattened. Hence the amount of the "arc swing" used is considerably more than with stock springs. The stock shackle is too short to accomodate all the fore and aft movement from the flattening of a longer than stock leaf spring.
Did I muddy the water?:o
I used to have an OLD rancho parts book that showed the flattened length of the springs. Thats what you want to compare...if you want to get technical. I'd just put a couple inch longer shackles on there and run it.
Tucker,
You gonna be at Katemcy? Ride in my truck when we are there and compare. I have the same springs and haven't had a problem. They ride pretty good. We'll compare at the ride.
Later,
Tucker,
Later,
I'll be there man ... just trying to make my junk flex a little better. You guys doing a boil again this year?
Tucker
Tucker
We might be able to do that. Hadn't even thought about it but we'll look into it. I'll let you know. See ya there!
Later,
