- Thread starter
- #521
Sometimes the inexplicable bird poop is explicable...
View attachment 1597006 I found the license plate I want to use on the Chick'n
If I can't use it on the back, I'll display it on the front like @ErikinSC
Without the luxury of a lift, this kit is going to take me a few months to install@CharlestonG8R , make sure you take it out and FLEX it a lot before you start.
The bushings WILL seize to the springs and bolts.
Find a ditch or a dirt mound and run through/over it multiple times.
You will thank me later...ask me how I know.
Without the luxury of a lift, this kit is going to take me a few months to installAnd thanks for the advice! I still don't envision the 45 heading out to the trails, but I wouldn't want the bushings seizing up. They got chewed up in the 40 and that was the culprit of my steering issues prior to the power steering upgrade.
ATF+Acetone; is that 50:50? I’ve got ATF, need to source some Acetone... Will need to try it on @girraffe ’s exhaust manifold.ATF + Acetone. Spray all bolts a week in advance, and then again a second time.
I know a guy with a lift if you want to knock out half at a time. Otherwise, a couple of jack stands and a few hours and it works.
Ahh, hence the gloves. Okay, thanks for the heads up. I was planning to use something with a more concentrated production like this: https://www.amazon.com/gp/product/B00004YK76/?tag=ihco-20You can mix it 50:50... but i just mixed it 1:1. I'm sure I have some acetone here at the house. Be leery of the dollar store squirt bottles, the capillary action is real.
