large male ends for rear wiper wiring??
Libertyville, Il.
Does anyone know where to purchase the large male and female ends that match up to the wiring ends for the rear window of the 55. I need to make a short esction up front of the blue with white line on it with the correct ends and don't know where to start.
Thanks in advance,
Goebs
Goebs; am a bit fuzzy on what you are looking for..is it the crimp on connectors?...there was a write up several months ago about the crossover with vintage japanese bikes sharing the same connectors as our Toys.........gave a website that I cannot find now; can you post pix of what you are needing?...might help
Lou
Lou,
I am looking for the connection at the end of the rear window dash switch. It is a plug type connection that is original. Basically a crimped on fitting that is larger then any I have seen. My camera is dead so I can't take a pic. I will look for some bike options. They have to be out there somewhere. I might cut the ends and make a new wire with the re-used ends by using inline connections.
Bullets Terminals & Connectors
I found this source but have no idea what size to order so I might get a few of each.
Are the ones from the motorcycle place the correct size to work with the existing male or female ends?
Thanks for the help!
Goebs
