- Joined
- Feb 3, 2013
- Threads
- 55
- Messages
- 225
i am upgrading my 55 to a MAF disc brake kit, so per the suggestion of other Mud members i decided to take on rebuilding my knuckles while i had it all apart. the whole area was a big goopy mess so i figured it was probably a good idea.
i am a bit daunted but i'm going through the process slowly trying not to mess anything up. i have two books on my cruiser but both are vague on the questions i have. so i have a few questions I'm hoping someone can answer.
My rebuild kit (SOR) came with two felt gaskets a larger diameter thinner grey gasket ( i assume this goes in the back of the knuckle ) and a smaller diameter thicker one. i cant figure out where this second felt gasket goes.
Metal shims
i noticed when i pulled my the knuckle arm off (as well as the piece on the bottom) that there were some metal shims underneath it. my kit came with new shims but there are various thicknesses. what do these shims do and how do i determine which thickness to use.
these shims have 5 small holes in them one on each corner and then one extra hole on one side what is the purpose of these holes which direction does the extra hole go.
GREASE
1 how much to use.
2 what kind to use
3 when do i put it in
Metal shims
GREASE
1 how much to use.
2 what kind to use
Now you get to learn the joys of a knuckle centering tool. As far as your other questions, here is the complete blow up of your knuckle:
