Knuckle grease amount
Colorado
I am having a hard time determining how much grease to pack into the knuckle when reassembling.
Everything says 3/4 full, but I cannot determine if that's just in the inner flange part, or in the entire knuckle. Filling the entire knuckle seems excessive, so I want to make sure before I pin this up. I reviewed other posts but I am still not clear.
Here's how much I have in there now:
Thanks in advance.
id use more. thats about "half" full. 3/4 full or even a bit more isnt a problem, but half full COULD be at some point... you want it to sling above the joint so itll fall down into it as it moves around. also it should be molybdenum grease.
Did you pack the inside of the Birfield?
When doing the Birfield and the knuckle, each side takes approximately 2 full tubes of grease (Moly)
The birfields are new from Slee. They told me they are pre packed. A tube of grease came with the axles, that's the grease in the pics. Unfortunately I don't have more detail as I am not at home.
I have a call into Slee to see what's best to add to that or if I have to buy more (probably expensive) RCV grease. I have a bunch of Valvoline Synpower grease that I bought on the advice of another post here. Hopefully I can combine the greases.
More; mine were about flush with the edge of the knuckle with some air pockets behind.
A little too much is better than too little.
just get black moly grease, nothing special. and after you get it all wrapped up and drive it a bit you can always fill it up as needed through the plug in the knuckle
When i helped my buddy rebuild and repack his burfield axles, we used between 1 and 1/2, and 2, 14OZ tubes of Moly grease. per side.
I use Valvoline Palladium grease.
After the birf is prepacked I add 1 pound or 1 tub to the cavity to reach the 3/4 fill guideline.
This is what I did too. The grease line on the wiper is right at 3/4.
This !
And Mine get a 1/2 tube every oil change through the service port. Whats not needed will be found on the knuckle via the wipers.
As others have said, more is better than not enough.
Is that 1/2 tube (6 to 7 oz) each engine oil change or gear oil change? That seems an excessive amount and would not only come out the wipers but be forced back through the axle seals into the diff.
This may be a dumb question, but what's a wiper? I don't see anything about that in the FSM.
I'm also having a hard time with the ABS rotor. Is there a trick to getting it off the old shaft?
The wiper is the seal you see on the backside of the knuckle. Felt/rubber/metal wipers. Keeps grease from pouring out the back.
This is just my opinion from years of working on paying customers cars, but pumping 7 oz of grease pre side into your burfs every oil change may not be the best idea.
Yes, with time some of the grease inside you're burfs will liquefy, and weep out past the axle wipers. But not 7oz worth per oil change.
So the most likely place all that extra grease is going to go, is right passed you're inner axle seal, and into you're gear lube.
I agree this sounds overkill. I top up as needed but its only once or twice a year and its less than 7oz.
All good info and all good thoughts. My gear oil is changed every two years and it's always looked good.
I tend to base my maintenance off my own schedule and needs. Works for me, but might not work for you.
Best,
John
If you gear oil does not get contaminated by the moly grease and you are adding ~7oz each oil change and changing after 10k or less miles the backside of the knuckles must be a mess as a result of not installing the components of the wiper seals correctly or the knuckle was never properly filled to begin with.
