Knock sensor questions
Missoula MT
Hi all I have some questions I hoped some one could answer. I Have a code 52 knock sensor that keeps showing up. It usually comes on when I am cruising above 2000 rpms. I had replaced the head gasket a while back and never got around to timing the truck tell a few months ago. It seems like the lite comes on more often now that I set it at 3*. The light turns off when I shut my truck down then is gone when I turn it back on.
Does the computer keep retarding the timing after I restart the truck and the light is gone?
Would advancing the timing help with the knock?
What else could I do to get this code to stop showing up?
The truck is a 94 with about 200,000 miles. Any help would be greatly appreciated.
Thanks
So I have been reading a lot and all I can find is to test the sensor because it may be bad. And the wire off the sensor to the computer because they may have a short? How do I trace the wire to the computer?
Thanks for the response. That is what I will do. Didn't want to through expensive parts at it without knowing.
One thing to keep in mind when it comes to the knock sensor fault codes is to check the integrity of the sensor wire, going all the way to the ECU. You'll need to find the pin(s) on the ECU by using a EWD diagram. In my case, one of the wire was faulty and gave me knock sensor codes off/on for years. I simply ran two new wires from the ECU to each knock sensor. Some day, I really should purchase a new ECU harness and be done with it!
IIRC, the wire on the front sensor is not supported well. We have repaired several that were frayed/loose/broken off. Pull wire off sensor very gently and visually inspect for wear/damage. I have seen them with several strands broken of so the signal to the CPU was degraded. John
Well an up date. I did order a new knock sensor. I have not installed it yet because I started to fuel up with premium fuel only and I stopped getting the code. Well almost stopped. It has come on 2 times since but it was coming on almost every time I drove it before. I still plan on putting the new sensor in when I get a chance. But if you are not using premium fuel give it a try.
That's good news but it sounds like a band-aid. Our engines should be able to run crap gas w/o throwing a knock sensor code. Hopefully the new knock sensor will cure your ills but do checkout the wires/connections too.
I too am getting code 52. Ive inspected the terminal as close as I can and the only thing I notice is that is very loose within the plug itself. The actually wire has some play in the plug. Do you think that could set the sensor off as well?
