Knock senser ?
Dusty 66
Ball & Claw Club
Nevada
Check Engine light came on when I was in Death Valley last week. 94 FZJ 80
so I took to my mechanic today he said that Knock Sensor wire harness was burnt and the sensor looked to be Ok he could not find a Toyota wire harness Toyota said discontinued, he said he could re wire it but no grantees it would work :frown: anybody have this problem what do you think ? Do I need this ?:confused: truck runs fine with out it
thanks you for your replies...dusty
You say that your rig runs fine but I'd be curious to know if the ECU for your engine reacts the same way as my 4Runner would. If the ECU "sees" a problem with a knock sensor, it protects the engine by fully retarding the timing, thereby reducing power. EDIT: Just checked my LX FSM, same thing, full retard.
Yes you are correct , I confirmed with the mechanic he said it would run 5* retarded he said to run 5* advance to compensate until I round up the part or make a wire loom witch he said would be a bandaid @ best, :frown:
I am going to check with C-Dan today Thanks......Dusty
C-Dan saves the day !
C-Dan saves the day ! :bounce2: Toyota 94 V6 pig tail P/N 82219-35010 Thanks Dan....Dusty
