I’ll post some tomorrow. It’s nothing crazy but good to go in informed.I think I read about that possibility. Pics are always good!
Passenger side:I think I read about that possibility. Pics are always good!
Bolt side side turned ok?Went to loosen the LCA a bit more to make things easier and discovered both sides rear cam bolts are frozen to the bushings. Soaking with kroil now. If I can’t break them loose with a breaker bar, I’ll try an impact. I’ve already tried a 3lb hammer on the nut side.
Just ordered new LCAs. Was on hold forever and then got a new guy who had new guy issues. Silver lining though is it took so long that when I got back in the shop, the kroil had done its thing. Pro tip from @bloc was totally removing the nut and washer. Doing so exposes the v-grooves in the bolt which allow the oil to penetrate down the length of the bolt.Bolt side side turned ok?
Edit: never mind.. forgot the bolt side is the rear on these.
If you remove the nut and washers on the front that’ll be your best path to get a penetrating lubricant into the bushing sleeve.
Just pull the bolts and put anti-seize on them? I don’t think it needs to be some sort of annual PMJust ordered new LCAs. Was on hold forever and then got a new guy who had new guy issues. Silver lining though is it took so long that when I got back in the shop, the kroil had done its thing. Pro tip from @bloc was totally removing the nut and washer. Doing so exposes the v-grooves in the bolt which allow the oil to penetrate down the length of the bolt.
Lesson leaned here is to bust those things loose as PM. Maybe even at oil changes.
I just had that thought. See my most recent post edit.Just pull the bolts and put anti-seize on them? I don’t think it needs to be some sort of annual PM
Went that route right out of the gate and it made the install relatively easy. There is plenty of metal even after cutting the front of the bump stop housing off. I bet if you left it like that you would not have any issues long term. Probably 45 min per side including cut, grind, cut patch, weld, grind, paint. The Nitro UCAs I installed came with some small diameter slightly extended bump stops that required no trimming. I don't have any pics at full droop but there is now a ton of clearance in this area.
I was gonna say the same thing. I did have to get into the frame mount but not nearly that much.Wow, you had to do a ton more gtinding than I did. I just ground part of the metal off the bottom part that screws into the frame mount.
