Killer 80 Series Video
that is the best thrashing EVER
Every time i see that i'm amazed that something didnt break. At least nothing major. I'd love to know more about the drive line of that truck.
Rookie, plain and simple. Too much beer in the blue cans maybe?
:lol:
Poor cruiser! Its sad to see it abused like that.
its fair to say all my cars get treated like that, when ever possible, and we build them, and maintain them to monitor the weakest links, and fix them.
The blue 80 was back from the mid 90's, captive coils, re valved Koni bus shocks, to get the length, bumpstop spacers, 36" swampers, turbo intercooled petrol 4.5, 10 psi 300 rw hp, button clutch, solid pinion spacers, laminated diff housings, full crome moly cage, 1996 - 1998. It used to hit 245 kph by terratrip[150 mph] rev limiter, top gear.
MY Nissan before that, renowned to be "bulletproof" managed to break all the body mounts off, tear the engine mounts from the chassis, break the panhard rod mounts front and back, tear the lower rear control arms off, and tear the steering box off the chassis, the first 8 months I had it, [lucky it was only a couple of years old....] running 35's with fuel injection, can grind, upped compression, custom Koni shocks, variable rate coils, roll cage, etc.
It replaced my 45 series with Bronco variable ratio power steering, 4 wheel disc brakes, chopped chassis, 35" tyres, custom bull bar, and tray, and modified leaf springs and mounts, with longer shocks.
The 45 and 80 both got a harder life than the nissan, for less failures.
The guy I sold the 80 to rolled it 3 times, writing it off, in the first 6 months he had it. The engine ended up in another 80 running lpg [propane] and 20 psi boost making 375 rw hp.
There was a new 78 series in there somewhere as well, 4.5, 36" swampers on 10" rims, lockers, Custom Koni shocks, and front coils, modified rear leaves, the tourer.
The shorty on Slee's old page was a 40 we built in 3 weeks for an event, in about 1999, 440 hp 454 chev, 60 gearbox and t/case, 75 series power steering, modified 60 series leaves, extended wheelbase by 8" tubbed rear fenders, lifted front fenders, roll cage, 36" swampers, Bilstein custom shocks, f & r lockers, was a fun truck, that would pull the front wheels off the ground in first gear :whoops: and would do 230 kph by gps [140 mph]
My 05 model Nissan running Fox triple bypass shocks managed to go 2 years before destroying panhard rods, tearing the front spring mounts and shock mounts off the chassis, and the body starting to stress crack in many places, was stronger than the previous model, but still no Toyota. It would cruise on 37's weighing 3.8 tonne [8300 lb] 200 rpm off the governor [diesel turbo intercooled modified] on cruise control, 20 psi in the tyres, dirt and gravel outback roads, remote travelling at 168 kph by gps [100 mph]
Hence I replaced it with Rooby, a 95 80 series, and a nicer truck, that currently has 37" tyres, 250 rw hp, Slee bars front and rear, and set up for touring, top speed 202 kph by gps. [125 mph ?]
We could only get 168 kph 100mph in the sand with 10 psi in the 37's last trip though, the old blue 80 would do 200kph [120 mph]
Its amazing how often this video comes up, from when Norman used it for what it was built for. :cheers:
