Key wont come out!
I'm out of the country and my wife is having the same issue with my 97 FZJ80. The key will not come out. It appears to be in park on the dash indicator but the shifter doesn't seem to be engaging fully into park. After installing a 1" body lift I often had to push the shifter forward to get the key out but she is pushing hard and it's not working.
Seems to affect Oregonians lol. If she's really hard up to get the key out I would be willing to meet her in Corvallis and have a look and see if I can effect a repair or at least come up with a good solution for a temp fix.
My brother in law was able to get the key out. He shifted to low and back a couple of times and final got the "click" in Park. Some cleaning may be needed. Thanks for the offer.
FYI,
This system is explained in the shift lock section of the EWD.
There is a key lock solenoid in the ignition switch which is controlled by the shift lock ECU under the center console. There is a shift lock control switch which I think is mounted to the shift lever (the location is not specified in the FSM) which tells the ECU that the transmission is in P and allows the key to be removed.
There are several connectors under the center console that would be suspect, as well as the ignition switch connector.
There are 2 fuses in play for the key interlock, both in the driver's left knee fuse panel.
15 amp CIG and 15 amp ECU-IG.
FYI,
Dumb question... what's an EWD? I need to look into this. I was having intermittent clicking in my center console (probably the shift lock solenoid cycling or something?) and intermittent need to use the override to get out of park. Now I need to use the override all the time, and the key can come out while not in P. CIG, BRAKE, and ECU-IG fuses check good, need to recheck bulbs, then I need to study the circuit and see about the best way to t-shoot. Looking at this thread, it could be the shift lock solenoid itself. But I'm picking up that a failure at any point, from a bad solenoid to a bad connector to a bad taillight ground could fail this circuit?
EDIT: Of course... hit post and it comes to me. Electrical Wiring Diagram?
The strange thing is that everything else works fine. The shifter is lined up with the gears, the dash lights (for the gear indication) match p perfectly to what gear it's I, but the key just won't come out unless I disconnect the battery. Anyone know of a secret switch/relay or something, or should I replace the ignition switch itself?
Running into this same issue - any steps to remediate starting with something simple (crossing fings) like adjusting the shifter linkage? I have no idea how to do this. Thanks.
Since one of the people here mentioned a body lift, I would check the adjustment for the shift lever. Not just the one under the truck, but the pin under the shift indicator in the center console.
On a recent shop project we had the same issue, only to discover that the pin for the shifter was tweaked in an accident, preventing system from realizing the vehicle was in park.
There is also a relay under the shifter. While it’s rare to see many of these relays fail, if it has, no signal will be sent to the computer to allow the key to come out.
FYI,
The switch is located directly beneath the shifter.
I don’t believe the fuses would have any affect on things as the key can be removed if the power is lost to the system And a fuse would do exactly that. They would be helpful for getting the key out in a pinch without disconnecting the battery, though.
Be sure the steering wasn't under pressure when turned off. Pull the wheel back. the recoil of the steering will jam the column lock. I do it about once a year. Hold the wheel at pressure CW or CCW then turn
Many thanks but this isn’t it in my case.
