I did not use an isolator since I seldom use the trailer while it is still hooked to the rig. When I get to my destination I unhook and go wheelin'. I did however use a self resetting breaker at the source to protect the circuit. The headlight harness and the trailer charge wire get their power straight off of the alternator instead of the battery since the voltage is a bit higher there. If I need to charge the camper batt I just hook up the cord and let the rig run for a while. To check the voltage I have one of those cheap Voltmeters that plug into a cigarette lighter.
I am resurecting this. I want to run a second battery in my trailer. I can pull out my 3rd brake controller out of my truck for battery charging purposes, but I really want to keep that in my truck since my camping trailer is only for my FJ40 and it is too small for electric brakes.
Is this what the self reseting breaker looks like if I want to run a line from the alternator to the quick connect on the trailer for chargning a battery? If so, I can "borrow" the one on my 3rd brake controller when I don't need it and use it in my cruiser.
Solar Power = High tech
High Tech and Harbor Freight =
Had one and it didn't work at all.
You need something that will cut off power when the battery is charged so you don't "cook it". Do you have a 12V converter on the trailer where you can plug it in to 120v power when available?
