Grade 8 bolts and fasteners tensile strength is 150 ksi and 6061 aluminum is 42 ksi so for the same size bolt/nut, aluminum is about 3.5 times not as strong. Doesn’t mean aluminum will fail in this application, as that depends on the loads.You could use steel instead of aluminum. I think the Slee kit uses steel. My Trail Tailor ones are aluminum and seem just fine after a year of use. Someone with more time on the hands could probably figure out the material strength of 5/8” aluminum bar vs the OEM bolts used… if the aluminum has a higher strength then the weak point is still the bolts.
