Since ownership of my 2013 LC200, I have noticed a little lean toward left side (driver side). I learned about KDSS lean but not sure. Hence hope to get some input. Everything is stock except upgrade wheels and tires.
Have this also, same direction as you. Notably it’s the opposite direction as usually happens in lifted trucks.
Also I tried the process in the above video and it didn’t work. Besides, preloading the hydraulics doesn’t seem like the best way to deal with this
I’m starting to wonder if it is caused by friction in the sway bar bushings.. when I get back from my current trip I plan to loosen the brackets at ride height and then reset the kdss valves and see if this helps.
Edit: forgot to mention I do have the 10mm OEM strut spacer in front, and no third row. So I am marginally taller than stock. About 1.5” of lean
My OCD kills me when I see my rig lean on the passenger side.
I'll try to perform the KDSS setup and see if there is any improvement. Also, I'm planning to lift the rig shortly after I decide on which setup to get.
