Kaymar opinions
I need a hitch. I need to be able to tow. My dirt bike misses me :)
Been looking at options and the quickest way to get a hitch without having to later re-do that part of the process is the kaymar rear tow bumper I think. Also it allows a cheap purchase and addition of the swing-aways later. Couple questions about this bumper:
- anyone have anything negative to say about it ? Speak now!!
- does this set me up for towing or do I need a wiring harness ?
- anyone know what harness costs?
FYI i have read the search but there are so many threads its hard. i've been at it an hour now and just want opinions
Thanks!
Thanks!
I checked one out, the rear tire moved WAYYY too much for my liking
Also, with the dirtbike on the hitch mounts the handlebars will hit the tire (but this goes for all of them)
All of them? The drawtite might put the mount out far enough to make a difference.
https://forum.ih8mud.com/showthread.php?t=104627&highlight=red+80+hitch
Going wheeling instead of biking? 6 bolts off. Be sure to use some locktite or other thread lubricant when you put it on if you plan to take it off.
Possilby
I dont go anywhere with my spare and sure dont want to be taking it on and off
Locktite? Thread lubricant?? :D
I only have the Kaymar wheel carrier mounted to the standard bumperette, but it is rock solid. It looks to me like the Kaymar rear bumper may stick out further than the standard bumper. Somebody who has a full Kaymar rear bumper may be able to confirm or deny this.
I have the Kaymar bumper on my truck. It is as close to the frame as it could be. I have no issues with a loose spare and have a 315 mounted on it. Most don't like the departure angle but that's do to the fact that you have a receiver back there. As far as the bike's handle bars hitting, I have no idea.
Kaymar tire carrier came with my 80, I don't like it. The hinge seems weak. I looked at mounting my hi-lift jack on it and it would barely swing out because of the jack's weight.
I have a Kaymar dual spindle bumper and swing away tire carrier on my 80. The spare is a stock alloy with a 285/75/R16 Bridgestone Revo. I use the hitch for pulling my trailer.
Nothing rattles, wobbles or otherwise offends.
M
Never had the spare tire move, it's solid. Great bumper for towing/expedition setup.
You will need to get a trailer harness, they're around $18 at Checker (Kragen), get the "converter" kind that will input your running, brake, turn lights & output the flat 4 for the bike trailer.
M
Ditto here regarding the Kaymar and exact tire setup. When I purchased mine Slee was not out with his tow bumper yet. That's your other alternative if you want/need and off road expedition bumper. I do prefer the hi-lift mount on Slee's bumper. The Kaymar is poor IMHO. Easy install.
No issues with the expedition and rock gardens I've done, but I'm not hard core either.
Regarding the wiring harness, stick with the Hoppy brand for about $45 online. It includes the converter box you'll need and has all the molex connectors for plug and play to your cruiser.
Ran a Kaymar on my XJ for quite some time with a 33x12.50. Worked just fine. Switched to 35's and had to modify it a bit to fit, but held up just fine with that tire too. Nothing came loose or bounced around/rattled. Ran the bumper through the Hammers here in socal... it held up just fine. Probably didnt hold up quite as well as some of the other bumpers out there... cause its not specifically made for rockcrawling.
Have no clue on towing, never towed with one.
Going to pickup another Kaymar this week, for my 80. Should be fine.. for expedition type use.
I've had my Kaymar for over a year now and love it. I have the swing away rear tire carrier and the swing away jerry can carrier. Both are VERY stable. For my use (expedition type wheeling) I think it's great. For rock crawling there are much better options. Can't comment on the towing as I have no experience with that at this time.
Just FYI, the Kaymar Jerry Can Swingout has a slot that can be used for the ideal beer bottle opener. That is if you haven't already gotten your TEQ opener from NorCalDoug!
I have had my dual spindle Kaymar tow bumper for 2 years and it has worked fine. I wanted the ability to tow and a spare tire as far right to the drivers side as possible. I had the top aluminum plate powder coated black to avoid the look of corroding aluminum or the work of preventing corroding aluminum.
I whacked it really hard in the quarry at Attica, IN. It left some character but the damage was very minor considering the force of impact. I have also towed a heavy car trailer without a hitch (actually there was a hitch just no trouble). I have had a little surface rust that I promptly stopped.
Kaymar here with tire and jerry can swingouts. I only have to open the spare tire to get into the back (can not in there yet).
It doesn't rattle and my latches close firmly. I'm happy with my purchase and actually bought it used. It doesn't offer as much 1/4 panel protection as some of the rock crawling oriented bumpers as people have mentioned.
I bought it from a rockcrawling "80" that felt the departure angle was hindered with how low the hitch sits. For me it was get the 285 Revo tire up there and provide more ground clearance. It is rated at 3500KG which is 7700lbs. The FZJ80 is only rated at 5,000lbs towing I believe and it would be uber slow in the hills.
