Build Kavik's SOA
looks good.
are you running the stock pitman arm? a sky flat pitman will work
I put my eyes on an 80 pitman arm today(less drop than a Marlin arm). Next up is a Mini 2wd(havn't seen it, but heard it has less drop). If neither is a good candidate, Sky will likely get the nod...
I'm runnign the Sky arm and It's a real nice piece. The nut on the rod end just clears the frame. It's as flat an arm as you can go IMO.
Which one? Zero drop?
Billet pitman arms vs stock arm.
Bpa-001 is the part # of the flat pitman
Bpa-225 is the part # of the 3/4 less drop than stock pitman
Hey kavik, where did you get those flex braided hoses on your front calipers? or i can prob. get some made just don't know the sizes. Or just buying them would be better. Thanks
I had them made...However, they were modelled after the longer of these 2 NAPA hoses - front axle outer hoses (skips backing plate) - NAPA 38881 (longer) or 38878 (shorter). Then I added a 90 deg banjo from Parker Hydraulics.
Before & After 90 deg fitting
Part # for the fitting
