- Joined
- Feb 26, 2003
- Threads
- 211
- Messages
- 1,859
- Location
- Sherwood Park, Alberta
- Website
- fawcusfitness.com
- Thread starter
- #101
Finally an update! Lots has happened!
So I got the big bolt off by welding up a tool (the compressor I borrowed would not budge the crank bolt either). The tool is similar to the SST in the FSM, I used that and a breaker bar…it was on there!
Since I wanted to look at the cam bearings the timing cover had to come off, as well as the side cover and valve cover and then this happened...
Side cover, valve cover, oil cooler housing, oil filter bracket, timing cover and oil pump housing have all been sand blasted primed, painted and clearcoated with plastikote engine paint. They will all be reinstalled with new gaskets, hopefully in the next few days.
Then this happened...why not clean and paint the block?
First I primed and painted the block with the injector pump and alternator still on as well as the oil pump housing (water pump staying). I was going to call it a day, but no, deep down I knew I would not be happy! So the alternator came off with its mounting bracket which I cleaned and painted black. I also ran a drill bit through the hole that the alternator mounts to as the old bolt was stuck in there pretty good. Also ordered a new bolt from Toyota as my old one was quite mangled.
Yesterday the injector pump came off. Removing the lines from the injector pump had me a bit worried! One of the delivery valves got loose in the process. I ended up checking them all with the torque wrench (torqued them to factory spec), they were all a bit loose for some reason. Once this was done I had to clean the block where the injector pump was (this was the cleanest part!).
For block cleaning I found that my drill with a little braided wire brush attachment from Canadian Tire was perfect for getting into all the little crevices, also used a screwdriver and hammer to knock off some stubborn rust flakes, then used brake clean after to wash it down.
Engine mounts and bolts were painted black as well.
Bellhousing is now red as are cast parts of tranny. Would love to do transfer, but I am not taking it off to sandblast (when it needs a rebuild I will, should be a while though as it was done about 8 years ago).
In case anyone was wondering. My painting scheme is this. All cast red, all aluminum gets grey, brackets and pulleys are black. The sidecover was lumped in with the aluminum because it is an oddball.
