Just dead
Germantown, MD
So had to jump start the good ole 80 this morning, sitting for few months. Let it run for 10 min then shut off. Battery wasn't at optimum charge when I tried to restart. So I tried jump starting again. After few cranks all lights just went off. Not sure what I just fried. Checked the 7.5 amp ign fuse, seems to be ok. Any idea? Is it the starter that might be dead? Thanks!!
EFI relay would be my bet. Check the fuseable link too.
Is that a picture of 97 or older fuse box? I will check again but when I briefly looked through the fuses in that box (mine looks different than that btw) didn't see any bad fuse. What else can take out the power like this? It literally has no electricity...like got hit by EMP.
That picture is from a 91 FJ80, although the fuse boxes are all quite similar. The EFI relay has nothing to do with your issue as it couldn't cause what you're seeing, or not seeing as the case may be. Folks love to blame the EFI relay for low tire pressure.
Most likely your fusible links are damaged and need to be replaced. They are available as a set of 3 from Toyota. You could also have a simple poor connection to the battery. Always look at the easy things first.
Sitting a few months is way too long. Batt looses approx. 1% charge/day sitting-then if more is drawing it down in the truck or the battery is getting old the battery won't have enough to startm if anything. 10 minutes won't even begin to charge it, especially if it was stone dead. Put a charger on it for 10 hours or leave it run or drive it for 1 hour plus without many accessories on, then leave the charger on it.
Thanks guys for the input. I will check with the volt meter then pull out the battery and take it to Autozone for charging. Only thing I'm not sure about it that it's a Marine battery (group 31)...might need to figure out if there's a special charging process involved I if they have right stuff for charging this. It had some juice left b4 the jump start. So at least one of the dash lights did lit up when I turned on ignition. Now it's all dark...I guess the last (2nd) jump start attempt took out all the juice from the battery? Also running 180 amp alternator with 200 amp fuse, that fuse is not blown. Sorry guys...I have been out of it for a while...need to get back in it again
Yep, I must have hooked it up wrong, it didn't recharge at all. Oh well, it lasted 8 years. Time for a new marine battery. Any one running Duralast marine from Autozone?
I have the AGM from vatozone. Not by choice, but my first duralast battery s*** the bed early so I traded up. It seems to be holding up so far, but the fit is not great. I have a 3/4 piece of wood under it to make it fit gooder.
You may want research running a deep cycle in a starting battery application.
