Series 80 Landcruiser Jump Seat Puzzle:
I found that the rear (3rd row) seats on my 1987 Landcruser don't
engage the floor catches. The trouble appears to be that the bent
3/8" dia struts are about 3/4" too short, so that the legs under the
seat are canted outboard at the bottom and just miss the floor
catches. It seems obvious that I could just straighten them out until
they are 3/4" longer (if I could remove the odd snap rings on the
pins at the "leg" end and get it back together again).
I'm reluctant to bend these struts. They seem to be in original condition as do the outboard wicket-shaped fittings that recieve the open end. It appears that the previous owner just detached the struts on the outboard side and let them dangle, allowing the seat catches to engage the seat locks near the centre of the floor.
Question: Is there any reason why I shouldn't heat and straighten out the struts to get the correct length? How could an installation like this go wrong?
The outside to outside dimension from pin to hook (that is, including
the diameter of both ) is 17 3/4". Looks like it wants to be just
short of 18 1/2", but I'm too chicken to start bending.
Thanks for your comments.
