JT Outfitters brake conversion problem
lelandEOD
Dayton, Nevada
This has turned out to be a lot more trouble than I originally thought it was going to be... :(
If I had known Poser supplied these parts before I bought from JTO, I would not be in the predicament I'm in now. (hindsight is a bitch)
So, I've got the JTO brackets and my metric GM calipers... the only problem is... they don't seem to fit. When I try to install the calipers, the steering stop adjuster hits the back of the caliper.
Also, I don't know since no instructions were included, but it seems that I should be reusing the spindle dust cover to keep crap out of the spindle... but since the disc brake bracket is thicker than the old drum backing plate it seems that the spindle rubs on the dust cover and may even prevent the spindle nut from being tightened properly.
I'm a little frustrated with myself over this. Any help would be appreciated.
Thanks guys.
Yeah that is a rear brake conversion kit.
Those look like the same brackets that are on your link...It does note in the web page that some grinding will be necessary on the caliper...doesn't look like a grinder has touched on to yours.
It also sez the steering stop nut and bolt will need to be removed to install the caliper. Evidently, it won't be reinstalled afterwards as it goes on to say "Don't worry, there is another one on the front"....
This seems like a lot of work for very little payoff. The correct Toyota parts are readily available and simply bolt together. Grinding is optional ;).
I recently bought a 1973 FJ40 that had bad cylinders all the way around. I put a JT Outfitters front brake kit and it wasn't that bad to install. We had to do the necessary grinding to get it to fit but the front brakes seem to be installed fine. The problem is now with the rear brakes. I opted to leave them as drum brakes like all my Toyota trucks have been (disc up front, drum rear). This has been a headache for a little while now and we cannot figure out what the problem is. As I said, I have a 1973 FJ40 and I am pretty sure that it has the original master cylinder (see attached) and booster on it. We put new aftermarket cylinders all the way around in the back and ran new hard brake line on both sides where it tees off. We have adjusted them to the point that the wheels will not turn but there is still a pressure/vacuum problem. They have to be double or triple pumped to get the wheel to stop turning. They have been bled until there is no air in the lines. We have even taken the suggestion to remove the residual valve from the front reservoir of the master cylinder but that hasn't done anything at all. It still won't grip until two to three pumps of the pedal. My master cylinder has the two separate reservoirs - should I go to one like a more modern truck that has one reservoir then tees off to the front and rear? Would a Toyota truck/4Runner master cylinder and booster work with my current setup? I have no clue what is causing this. When we pump the brakes, the rear brake reservoir fluid goes down but then goes back up after the brake has been released. Any help, suggestions, advice would be appreciated. Thanks.
First thing that comes to mind is some aftermarket cylinders don’t have the bleeder at the top of the cylinder and they may still have air trapped in them. Sometimes the cylinder angle needs to be changed while bleeding to get the last bubbles out.
Other than that, the shoes need to wear into the drum to get and then be readjusted. Also a larger bore master cylinder that moves more fluid can help.
If changing masters, I’d highly recommend an ‘89+ master and booster out of an 80 series. With 4 wheel discs and an 80 series booster my braking is crazy powerful... can’t garantee the same results with a JT disc conversion (not a fan and prefer OEM discs for the front).
Thanks for the reply. The bleeders are in the right spots. There is no air nor is there any more room for adjustment on the drums. I know, JT Outfitters equals bad apparently on here but I’ve had no problem with their customer service or products yet. The front looks solid so far, it’s the rear or the master cylinder or booster I guess. Has anybody converted their front to disc via the JT kit and had problems with the system after working on their drums?! If I have to replace my MC and booster then that’s fine. Since it’s now a disc front, drum rear can I just use a regular Toyota setup for the MC and booster?
