John Deere HIRs for Low Beams
CruiserDan-
I always suspected the tractor's torque advantage - do you recommend full synthetic headlight fluid to handle it? ;) BigMac
The package says 130w on it. The bulb says 65w. They are bright, I have no idea on the heat. Some guys on the 100 series yahoo board from australia have been running these ipf 130 hir's for two years with no issues.
They were a bitch to find, had to get the phone # from the ARBUSA through email. I can not find the number, the place is ok auto in new jersey. I could not find them listed on any website.
Andrew
[quote author=uzj100
Andrew
Sounds like some sort of headlight speakeasy. Was there a secret knock or password? They ship them out to you in coffee grounds? ;)
I've personally always had this dream of having headlights so bright that insects burst into flames when they fly through the beam. 8)
I found the site, even thou they do not have the bulbs listed. This is where I ordered them from. I told him I was told $110 by ARBUSA and he said he could sell them for that, like the is another price or something.
Roane
www.ok4wd.com
[quote author=uzj100 link=board=2;threadid=3900;start=msg32183#msg32183 date=1060863350]
Andrew
[/quote]
I'm going to call bull**** on the 130 watt. This sounds like the same crap as where PIAA takes a 65 watt bulb, plays with the filmant so they can measure a higher lux output because the light is concentrated over smaller area and then call them "100 watt bulbs". The bottom line is that incadecent bulbs are all about the same efficiency and put out the same light output for the same wattage. It is not until you go up to things like HID lamps (i.e. mercury vapor, metal halide) which are about 5 times more efficient that you can get a "free lunch" where you are getting a 35 watt bulb with the equivilant of 150watt incadecent output.
Frankly, If I was going to spend $110 on a pair of bulbs and another $40 for a harness, I would save up and get a true HID conversion (hids4less) for the $400 or so they run now. No need for an upgrade harness, expensive, but true high output.
Cary
[quote author=cary link=board=2;threadid=3900;start=msg32005#msg32005 date=1060799050]
Why waste the money on the John Deere's when you can get Hella 80 & 100 watt bulbs for $10 each? ???
Cary
[/quote]
Where can you find Hella's for this price? The only bulbs I've found this cheap are just that.
[quote author=Jomama link=board=2;threadid=3900;start=msg32217#msg32217 date=1060877993]
[/quote]
http://www.rallylights.com/hella/standard_bulbs.asp :D
9005 & 9006 bulbs, I lied they are $10.25 each
Cary
Cary,
Nice link - thanks. I ordered 6 pairs of bulbs from them and was amazed at their pricing. Spent what I was considering for the John Deere's and got all new bulbs for both vehicles. Now I'll be looking for Wart's NAPA connectors and will beef things up a bit to see if I get substantial improvement with a relay and heavy wire.
IdahoDoug
Andrew
[/quote]
www.ok4wd.com is our local 4x4 shop here in NJ. Ask for pantywearing Chuck when you call. He's a good dude with a couplo cruisers including one sick 40.
So what's the final analysis on lights? Good? Cheap? Worth it? B? Cdan? Christo? Rogue? Others? :flipoff2:
I ordered some lights off of rallylights.com awhile back and the DS low beam blew in a weeks time.
My current setup is:
1- 55W DS low
1- 80W PS low
2- 100W high
It works good enough. A bit ghetto, but that is who I am... ::)
Um, possibly.
The stock bulbs are fairly good compared to other vehicles. I regret spending the money on those bulbs now.
If it ain't broke, don't f with it. Don't tell BYU about that one either. ::)
kstone said:
The John Deere part # is AH162232 and the price each was $28.55.
Thanks
Where did you end up getting ahold of them? I tried their website with no luck, says invalid part #. Did you order them direct?
Thanks
EDIT: FOUND EM HERE:
Looks as if IPF Makes em for both low and high beams, anyone tried these yet?
http://www.offroadtuff.com/IPFbulbs.htm
Boston,
That's about 30% higher than you can purchase them from at www.danielsternlighting.com
Email Daniel with your vehicle info and he'll send 'em. Do searches here on HIR and you'll find there are literally dozens of us with the good version of these (who makes IPF's?) and they're working out very well.
DougM
IdahoDoug said:
Boston,
DougM
Thanks Doug, cmon now, none of this "Do a Search" bashing now, i have already done that, which is how i found this year old thread in the first place! :D :D
What version do you consider "Good" exactly??? I have heard nothing but great things about IPF lighting and accesorries
Also, Thanks for the heads up on the pricing!
BTW, in all of my searching, i dont remember anyone saying where they actually bought them from
Thanks
Hmm. Do a search on "Group buy" and "HIR" and that should cover it. I believe the "good" ones are made by Toshiba. Someone or several got one of each mfr and compared them.
DougM
DougM
Got It! Thanks!
