JDM a/c drier relocation kit
Took my LC to an a/c shop to see what they could do since it's getting warmer here and my refrigerant escaped when I caught my drier in the mud/snow somewhere.
They wanted to use rubber flex high pressure hose and quoted me $350 to relocate drier to battery compartment. Doesn't look like that large hose would leave much room for an Odyssey battery or might also make changing headlight bulb a matter of removing headlight assembly. Don't know how the flex hose would work, but I passed. Sure hope this becomes a viable option.
Given the tight quarters we're working with (especially if you have a big battery) I don't think the rubber hose is a good alternative-I think you made the right call.
We're up to [STRIKE]42[/STRIKE] [STRIKE]43[/STRIKE] 44 folks showing interest!
I'm in for a kit 100%.
Update on where we are:
I've received the lines from Steve and Kevin, thank you both! I assembled both lines to the driers and took multiple photos, so the fabricator can see what they look like. Then I packaged them up and sent them out on UPS yesterday afternoon.
A couple things I'd like feedback on:
1) Does anyone think we should keep the sightglass? Realistically, it is of limited value and will undoubtedly add to the price.
2) I've been debating adding a rear A/C unit to my 80, and this would be the time to add a fitting to the line for the rear unit. Maybe one that could be capped, so it could be used at a later date. Again, this will add to the price and might not be worth it.
Here are a couple pics of what they look like side by side.
I would interested in how much more it would be to have them both.
IMHO
Thanks Stu
How much "additional" are we talking for the sight-window and rear AC options? $20?, $50? I assume you are speaking of having one sight-window on the top of the dryer like the '91's, not having two windows like in the '94+.
:cheers:
Steve
:cheers:
Steve
Yeah Steve, only one sight window like the 91.
Both of those options are of interest to me, depending on price. Thanks again for your coordination of this.
The sight glass might be useful, but I've never bothered looking at it yet in 10 years, so I'll doubt I'll miss it:p. Your AC either's cold or it isn't, right?
I'm a vote against the rear AC pipes. Never felt the need for rear AC. But then again I never sit in the back of my truck.:rolleyes:
1. I say lets ditch the extra sight window, if one is already available at the top of the drier.
2. Include the extra line for the rear with the thread-on cap.
Thanks for doing this.
I would like a sight glass, it makes for quick diagnosis and monitoring of the a/c system. If there's a sight glass on the receiver-dryer that works fine for me.
I hate it when I have to work on an a/c system and there's no sight glass. Then you MUST rely on gauges instead of having a quick check.
My vote is to not have a rear line capped. I just think so few people have the chops to actually implement something like that. The juice ain't worth the squeeze in my opinion.
Sight glass - yes, because I would like to have the replacement lines work like the OEM lines if it is time for diagnosis.
Rear A/C - I have no plans to add rear A/C; so I can not realize the value of an extra fitting.
A quick update
The fabricator has received the lines. We talked about the sight-glass, since most seem to want to retain it, so he will look at whether it's more cost effective to have it inline or on the drier fitting. We also came up with an easy solution for adding a line for the rear A/C. He can build a "T" fitting, that would go into the connection that is along the fenderwell, and allow a line to go out to the back. You would only need this fitting if you were going to put in rear air. He is in process of figuring out what's involved in building the new lines and said he will have more information on Monday, so I'll let you know more as soon as I hear from him.
Interested as well.....:popcorn:
Thanks for the update..
I think a sight glass is useless in any application. You guys are going to have a lot of fun when it comes to adding rear a/c. I love the idea, and if somebody has the determination to do so, I applaud them. Making a/c lines is not that difficult, but it isn't much fun either.
Just a few words of advise, don't forget about the low side line that will need to be adapted to the rear evaporator, you'll have to splice it in too, but that is probably is a given for most of you. Once you have that done, then comes the real fun, how much more capacity do I have? I need 4 more ounces of oil and 1lb of refrigerant, or what? What expansion valve am I going to use back there? Maybe I ought to adapt the high side line back there so I can play with orifice tubes instead? Do I need a smaller pulley on my 10PA17C? Is there enough tensioner travel to accommodate a stock belt if I do? Is my condenser large enough to dissipate the heat? I probably need an electric fan to help cool everything down, huh?
Where I learned a/c, we did a few things of this nature. I know a few of our member's V8 FJ60's, done by a guy in the DFW area, were brought in to the shop. I had my reservations about taking a compressor that is junk, Denso 10S20F, and switching it from an orifice tube to an expansion valve (making the necessary fitting/line mods), but it wasn't cost effective to put a better compressor in place. I'd bet that most of those compressors have failed.
If anyone local wants to do this, I'll help as much as I can. Also, if you want the high side lines to relocate the drier, I have the FJ80 lines. I don't want $$, just come and get them. A new drier cost me $3, and I'll throw that in to any interested party. The lines might be a bit mangled from the wreck, but they never leaked. If they need a weld to reinforce, I know a guy.
I love doing things such as this, there's just no need, or desire to tackle the job on any of the vehicles listed below. Well, maybe on the 40.
