I just down loaded the pictures from the camera and am still sorting through to see what is worth posting, but I thought one from Todd's log climb needed to be posted tonight.
Nice videos Andy!
Ok, I told Landcruiser Larry I wouldn't post this but I just have to...sorry Larry, I just love to hear the sound of that turbo whistler!!!!!!!!!!!!!!!
YouTube - Royal Blue Run![]()
Andy - Thanks for posting the pics and vids on Photobucket. You da man!!! Good crew you run with too. Glad to see my old 40 has gone to a good home with Mr. Sharp.
This will give the guys at work a laugh, because I was telling them about my error and now they will get to see it.
Thanks ... sort of.
Larry, tell those of us that werent there with you guys what happened? Video shows your submarining your LC, but then ends...what was the result?
More videos available. Grand total of 7.
Andy...Thanks for the Videos! Wish you had been there on Monday to film some of the trails we found![]()
if you are burning a ground wire, it may not be a tipical short per say. it may be a "lack of proper ground". something is searching for and/or you have a weak ground elsewhere. check to see ground at battery and starter (if it came with a ground at starter from factory) is in top condition.
secondly, if it is a short, and a fuse did not blow, i would look at the main feed wire feeding the amp meter and/or fuse block. it's generally the only wire without a fuse. sometimes there is an inline fuse at battery feeding the main wire but this is not the issue in your case. it would have already blown.
#1, check all other grounds. "clean them anyway".
#2, check main feed from batt and/or alt feeding amp meter and/or fuse box. water caused short is suspect. wd40 may be the cure.
one of these will be your culpret.
good luck, bob
Had a great time on the trails! Can't wait 'til the next adventure.
Did you and Sean/Shawn (sp?) sorry, stay for Sunday?
We need to get the Knoxville guys together sometime...
<<<<<<Marius got his truck dirty![]()
Saturday
It was great to see you all and what a turn out, hope we can have more rides like this one.
You all that had to leave early missed the really good trails. Monday we found the trail leading to the old sand quarry area. There is a long steep rock climb to get up to it, then open trails, sand hills and assorted side obstacles. We need another weekend just to explore this area. My dial up connection with wet phone lines does not want to open the pictures this morning will look at them later.
