J spring question
I am about to buy a lift kit for my 80, and as usual, am feeling a little weary about which height. I probably wheel about once every two months, I have a dual swing out spare tire carrier, and a TJM style front bumper with plans to add a winch. I do tow about once a month. I decided to get all the accesories first, to see how much of a lift I really needed. Needless to say my back sags when I tow, and with the weight of the rear bumper, currently the back is about 1/4 of an inch lower than the front. I was thinking of getting the Jsprings and running 285's or 295's. I don't want to regear, and I don't want to deal with vibe issues (who does, when they don't wheel that often). I thought that with all the weight of the rear bumper, then the J springs would be perfect......but going through the registry, and the FAQ's, it seems the Jfront/Heavy combo or the Heavy front/Medium combo may be a better choice. I'm also concerned with the look of a smaller tire with the J springs. Is there really any point in getting J springs if you're not planning on running tires bigger than 33inches? Most of the rigs that I see on the 80 forum with Jsprings are running 35's or bigger, but I don't see than many rigs with Jsprings running 285's, 295's, or 305's.
I can't say enough about how much I appreciate this forum, With your help i was able to do my head gasket by myself, as well as find all kinds of useful information on the FJ80. Any information or opinions would be great. :flipoff2:
It sounds like the Heavy front/Medium combo would be the best for what you want? Lift, tire setup depends on local terrain, weight, how you intend to wheel, etc. The best bet is hookup with a club and see what works locally. Around here one of the most effective setups is J front, heavy rear, L shocks and 315's, fits, flexes well, but anytime that you go above the standard 2.5" the chances of issues are higher.
A pic of mine with J's, 1.5" front spacer and 295's. More than needed for 33's, but works great with 37's!:hillbilly:
attachment.php
Thanks for the input. Nice rig, looks great without the roofrack. Few questions....where did you get the spacers from? Did you make the spacers yourself? and did you have any issues with the setup that's in the picture as far as vibration. Do you have any weight in the back?
Here are a couple of pictures of my LX. Before and After. I installed OME heavies up front (have spacers that are not installed yet) and Mediums in the rear (also with spacers that have yet to be installed). I will be installing sliders and an ARB with a M12000 in the next 30 days. The ride is awesome and I have had ZERO driveline issues, vibes, etc. Meats are REVO 285s. No need to re-gear with this set up. Of course, I am not into hard core wheeling and such. Definitly check with your local club to see what their reccomendations are.
Josh
I personally prefer a level stance. Therefore id be tempted to go with either (F/R) J/heavies, heavy/med., or maybe even just heavies all around. I think for your tire size and desire to stay out of driveline issues, and plans to tow, i would opt for the HEAVY/HEAVY combo w/ slees blue bushings. You may have just a hair of stinkbug, but when loaded down or towing it will be nice and level. Here is a heavy/heavy lifted 80 w/ just an ARB up front/on top and 33's.
also here was my 80 w/ 285's on a J/J and l-shock lift for the first couple years i had my truck while in otherwise stock form (no armor). No vibes, but shy on castor w/ just the yellow bushings. I believe w/ your weight of armor, and w/ the blue bushings you would be fine, but a guess noone could garuntee.
and another local member w/ heavies all around + a front spacer and blue bushings
edit: i believe that is pre spacer up front and he is also running 35's
My spacers were the prototype for a run of them made with help of a machinist buddy.
https://forum.ih8mud.com/az-copper-state-cruisers/79654-csc-brand-fj80-front-spacers.html
I had some vibration issues, they were relatively minor and mostly solved by changing the front shaft to in phase, from the factory out of phase. It still has a slight vibration, just tells me when it wants grease:hillbilly:. At some point will have a Taco/Tundra shaft shortened for it, but it's not a priority.
There are several J-heavy rigs rigs here with great results. In my experience caster has a much higher effect on vibration than lift. So the trick to making a slightly taller lift work is correcting the caster only enough to net a comfortable driving rig, over correcting almost always causes vibration. Most here with this setup are running 3 degree bushings and a little extra toe-in and drive great with no vibration. Tires also come into play, the rigs with 315's tend/seem to drive better with this setup than 285 rigs.
Mine is close to stock, as pictured it was ~5200lb, now (bigger tires, compressor, etc) it weighs ~5400lb. For the wheeling that I do weight is the enemy and IMHO it's too heavy stock, so any mods have to pass the do I really need it and is the trail benefit going to be enough to offset the trail performance loss, test.
That said, with any lift there is the risk of issues, the taller the lift the greater the chance. So it's up to you to evaluate the need, want versus risk of extra mods/work to make it work, that your willing to take. If your risk averse, mechanically challenged, your probably best off going with one of the more proven kits, but even then there is no guarantee that it will be perfect.:D
With the (f/r) J/heavy, do you still need to get long shocks in the rear, and if you just go heavy in the rear, are you going to need to get longer brake lines? Thanks for the pics, The gap between the tire and the fender in the picture of your eighty is what is making me back off getting J springs, but I have a spare carrier, and front bumper, and plan to add sliders and a winch, so I guess it may lower that gap in the long run. Is that your 80 as well behind the blue one?
IMO, if you are going with J front and heavy rear, you do not need to get a long shock in the rear and you don't need a longer brake line either but you have to get a 2 inch round tube and use it as a bracket/spacer to lower the parking brake line located just below the middle frame. On my rig, I have the 850J with N73L long shocks up front and 863 with N74E in the rear. I still get a stink bug due to ARB bumper and dual batt, I also have the Kaymar Deluxe bumper in the rear. I have not got the chance to install the blue bushings or Slee caster plates, but still drives fine with just a little driveline vibes. I'll show you some pictures later on.
If I were you, I will get the J/heavy combo if you are planning to install what you described on previous post.:cheers:
The stinkbug in your link looks crazy. you sure you had the j springs on in the front...:eek: Are those the 295's that are on your first picture?
This first picture is my truck when it had OME mediums and 1.5" spacers. It rode really well on the road with RS9000 shocks but was too soft and if we loaded the truck is was MUCH too soft. This is with 315's.
A couple years ago I swapped to J springs F/R and OME L shocks. I like the added height and it's still quite stable. I'm still using 1.5" spacers too. The J springs have a little more body roll in corners than I like, but otherwise they are fine. I am planning on going to OME 5" comp springs instead sometime in the future. They will be just slightly taller than what I have now but after riding/driving my friends truck with the comp springs they handle/feel much better than the J's in my opinion. I also would like to move up to 37's soon too.
Please disregard the orange lines this picture was used before to indicate the length of my sliders. J springs, 1.5" spacers, L shocks, Bumpers (makes a difference vs no bumpers).
HTH.
If your referring to the green rig in the link, that's Geo Ross's IIRC heavy front with 864 rear and 285 BFG's. If your referring to the linked in the linked page,:D the white rig is mine. That is a setup that I got a killer deal on used, heavy rear and mediums front, so yep tons of bug. Only ran that a couple of months, several others got rigs at about the same time, we did a group buy, a bunch of J setups at once.:hillbilly: Ran the same Nitto 295's until I switched to the 37's last year.
HTH.
Nice rig...is the above picture with 315's as well? Also, I notice you never mentioned any regearing. Did you? If not, do you have any vibe issues?
while maybe not necessary for the medium, i might still get the extended brake line in back. For one the stock is only barely long enough for mediums. The other option is to lower the bracketry holding the brake line. However the braided steel may provide better braking performance.
yeah 315 Goodyear MTRs in the first pic. 315 BFG ATs in the second. Still stock gearing. The truck had 35's on it when I bought so i don't really know any different. It's never been a problem for me.
I have a DC shaft in the front, and adjustable upper rear arms (that I haven't installed) so I have a little vibration in the rear right now but the u-joints are worn. With new u-joints and finally getting my arms installed I'll be vibe free.
follow up to my question
I ended up getting the J springs afterall:grinpimp:. Getting them from TRDparts4U seemed like a pretty good deal. In hind sight, I would have gotten the SLEE caster correction bushings instead, and I would have probaly held out for a set from the classifieds on this forum. It's funny how things work, but right before I was about to start the lift, my front axle started clicking on the right side:eek::mad::bang:, so I called Cdan and got the parts ordered for a front axle rebuild. Something I had been dreading for quite sometime. Many thanks to Buckru for driving 50 miles one way to bring the technique as well as some moral support. While I was waiting on the parts from CDan I decided to install the Slee extended brake lines, as well as the OME CC bushings. I ended up destroying two of the steel brake lines by using a regular 10mm box wrench instead of a flange type brake line wrench. I made my own, and every things came together well as far as the brake lines. I still ordered the brake lines from Toyota just in case the home made ones start to leak.
I wasn't able to get the control arms to line up with the mounting holes when I tried to put them back in. With a few searches on this forum, as well as some inquiries on the T4x4T forum (thanks to notyourmomslx450 for helping me figure it out.), I was able to pull the axle back so that the control arms would mount.
Next came the lift. The Slee instructions were pretty helpful. I ended up cutting the top nut of the DS shock. I can't afford Snap on tools, and I got new hardware with the new OME replacment shocks. I don't recommend it to anyone that hasn't used a cutting wheel, since the ABS lines are dangerously close. Luckily my hands cooperated and I didn't have any accidents.
Since I did the lift by my self, I had to use the factory tire jack to spread each axle away from the frame. I rested the base on the top of the axle and erected the piston up to the frame so that I could fit the J springs in. I had to do this for each spring. I went with the Slee one inch spring spacers in the front. I still had a little bit of bug, but after riding for about 500 miles, it has settled the rear to where it's only a 1/4 inch higher in the rear. The last pic shows what it looks like with some cargo in the rear....hi-lift, cooler full of food and beverage, 5 gallons of water.... etc. Sorry, I didn' have any close ups of the truck after driving 500+ miles.
I got a real cheap worn out set of bfg 285's to see what it would look like. I'm glad I didn't buy a new set of 285's cuz now, I have my heart set on 35's. It just looks better. :meh:
Thanks again for all your input, and for all those who helped out. :flipoff2:
looks way better! Any vibes? So you are running just the yellow CC bushings? Is it squirrely? Mine was insane with stock bushings.
Thanks, I' like the way it looks too. It's pretty squirly, with the yellows. I'd hate to find out how it is with just stock bushings. I'm going to be in the market for some plates and/or blue bushings after I get my tires, but for now I'll deal with it with the worn out tires I have now.
My vibes came a few days later. started on decelleration and then started showing up at wierd times.
its a little rough, eh?
Yeah, mine started on deceleration, and after wheeling last weekend, I get some at the begining of acceleration. I need to retighten my bearings after my axle rebuild. After that, we'll see if it's still rough. Lengthening the drive shaft is going to help with the roughness I think. I saw that you did a Jspring lift on yours, hope to see and compare ours in the future.
