Started a knuckle rebuild in September of 2017. Completed the rebuild in November and swapped out the old Heim Joints with new tie rod ends and a Marlin Crawler High Steer kit from Valley Hybrids (Stockton, CA). Also new/rebuilt calipers and rotors. Right after the front end was complete, the clutch went out. Had to replace the slave cylinder.
In January, I started to focus on the brakes. Every since I changed the front brake lines and put on the new calipers, I had to pump the brakes in order to stop. Kinda scary so I didn't drive far. I probably went through $100 of brake fluid bleeding the air out of the brake lines, but no change. Then I noticed the rear brake canister started losing fluid. I would fill it up, return the next day, and it would be empty. No leaks anywhere or fluid on the ground. Started reviewing the IH8MUD forums and decided the master brake cylinder was bad. Purchased a new one and after reading about brake fluid leaking into the brake booster, I checked the check valve. You guessed it, brake fluid in the booster. I pulled the brake booster and the bottom portion was full of brake fluid. I emptied it out.
I've read all the forums and I decided to purchase a new brake booster instead of putting everything together and finding out the booster was bad. Face it, we're not Cruiser nuts because we want to save money.
I have front disc / rear drum and the PO had a single diaphragm brake booster. I want to put on a duel diaphragm brake booster, but I'm worried the brake cylinder will run into the carburetor. Any thoughts? I plan on purchasing a brake booster from City_Racer, $250.
I included some pics of some of the work. I don't want to
but like to hear from the experts.
