It just died!
Ok ive replaced the ingnitor, the efi relay, the distributor, checked both the positive and negative sides of the efi relay (good), checked coil ohms (good), at this point im wondering what all you guys see in these things. since ive had this thing for less than 3 months and ive already put all kinds of $ into it just to keep it running . If it was a jeep it would have been back on the road the same day it went down, Does anyone have any other ideas what the problem could be PLEASE its my wifes DD and she needs it for school:bang::bang::bang::bang::bang::bang::bang:
Man, this is killin' me. I'm pretty well versed in the FZJ which has few and well known issues but the FJ has even fewer issues. Looks like you're good with electrics and have followed an excellent protocol. Now it's down to weird issues and perhaps the previous owner has left you with a mystery.
Here's a short list of oddments that have been the culprit over the years in autodom.
Previous owner installed stereos, etc blowing fusible links in the harness (no outward change to link, btw)
Security system.
Ignition lock cylinder issue/dirty contacts.
Oxy sensor wire dragging on driveshaft.
Engine CPU connection disturbed by previous owner deinstalling something.
Crank position sensor.
Broken timing chain (you'd presumably notice different cranking feel/sound.
Can you hear the fuel pump pressurize the system after it has sat for a while?
Frayed fuel pump wire in gas tank (accessed easily through floor hatch).
CPU getting wet from a blocked sunroof drain tube, or a dislodged one.
You've got a pretty good attitude for someone throwing $100 bills at your Cruiser. Plus you have to live in Bakersfield......heh....
DougM
I hope you get this figured out, I'm getting scared, what happens if this is the end all our LC's face, a mystery virus. No one has said it but you.......is there anyway you could borrow an ECU, plug it in and give it a shot. Or is this an incredibly bad idea? If something fried your ECU, will it fry the next one as well?
You could also pull your ECU and give it a look see, maybe you'll spot something fried. Good luck to you
I once had car completely lose power and later discovered the alternator connector pins had fused together inside the plug. I've also had start issues with my 80 because of the alarm system. Don't know if this will help. Good luck!
Mine died one time a year ago doing 60 MPH in traffic. Had it towed home and started checking the Distributor. No spark so l first replace the rotor and I was go to go for over a year now.
Oh, you're trying to read codes by jumping TE1 to E1 on the check connector right?
I don't think that's gonna work until the EFI problem is fixed as the ECU needs to turn it on in the first place.
Have you messed with the Air Flow Meter at all? Try unplugging it and see if the CEL comes back. The truck won't (shouldn't) start as the fuel pump will be cut off, but there have been some folks who had internal shorts in the AFM screwing up the works.
BTW, the parts you are throwing at this...are they new OEM Toyota parts?
